ATmega88 led heart circuit (smd led effect), Led Heart Circuit Music Box RGB Led Effect, RGB Led Heart Circuit PIC 12F629 Mood Light, 30 Led LED Heart circuit made with PIC16F628 as an alternative to circuits..
PIC16F628 Software There is a source .pbp and .hex code prepared with Picbasic. Also Proteus simulation scheme, PCB file is available. Control layer is designed separately, open led holes on the heart or the shape you want and create it, then assemble the leds.
There is also an LED Heart template drawing, you can print it in the appropriate size and use it. 5mm LEDs are used in the project. Leds are connected in groups of 3 in parallel.
LED Heart Study
source: elektroarge.com/viewtopic.php?f=107&t=209 @K@r@CaLı
LED Heart Circuit PIC16F628 ZIP File Password: 320volt.com
