Toroidal Core Winding Method (Practical and Easy Technique)
Winding a toroidal core is one of the most tedious tasks for amateur electronics enthusiasts. Especially if there is no hand skill or practice, this process can become quite tiring. Although toroidal winding machines are used in professional production, access to such equipment is often not possible for hobby purposes or one-off projects.
In addition, finding suitable soft copper wire to be used for toroidal or ferrite core winding is not easy in every region. For this reason, most electronics enthusiasts have to use motor winding wire, which has a harder structure. Winding with hard wire makes the process even more difficult.
There is a practical toroidal core winding method that can be applied at home with simple tools.
Practical Toroidal Core Winding Technique
The biggest difficulty in do-it-yourself (DIY) projects is having to constantly pass the long winding wire through the center of the core.
This process both takes time and causes the wire to get tangled.
To make this problem easier, the following method can be applied:
Preparing the Wire in Spring Form
First, the wire to be wound is wound in a “spring form” so that it can pass easily through the core.
Thanks to this method, the wire becomes controllable as if it were being used in short pieces.
If long windings will be made, the middle part of the wire can be left straight, and only the beginning and end sections can be prepared in spring form.
This also significantly speeds up the process.
Fixing the Core
To make the winding process easier, the core should be fixed in a vise.
Fixing the core both ensures that the winding is neat and makes it easier to control the wire tension.
Winding Technique with a Hook
Using a long plastic hook, the wire is passed through the core.
This method eliminates the trouble of constantly passing the wire by hand.
When the wire is tensioned and wound with the help of the hook:
  • The windings become tighter
  • The wire fits the core better
  • Gaps are prevented
  • A more professional appearance is achieved
Toroidal Core Winding Method Video
Toroidal core winding can be a very difficult and time-consuming process when the correct technique is not used. However, this process can be made much easier with simple methods such as preparing the wire in spring form, fixing the core, and using a hook.
Thanks to this practical method, it is possible to make toroidal windings both faster and more neatly.
Source:bit.ly/40en5U3
