A powerful calculation software for engineers. The program can greatly increase your productivity by eliminating the time spent searching for formulas and manually performing the same calculations over and over again. The software quickly and efficiently solves a wide variety of common engineering problems. The program module and data table are combined in a single easy-to-use package.
With this package consisting of an engineering calculation program and data table, you can complete design work that would take hours within minutes.
With engineering technical calculation, a comprehensive library of basic engineering data is always at your fingertips.
The programs allow you to quickly determine component dimensions and check whether your designs are within limits.
The Engineering Power Tools program is paid software, but in its standard version you can use many calculations free of charge for 30 days.
At the end of 30 days, you can clean it with the “Uninstaller” program and install it again 🙂
Mathematics
Contents
- Area of Plane Shapes
- Calculator
- Conversion Factors
- Engineering Constants
- Fractions-Decimals-Millimeters
- Orders of Magnitude
- Triangle Solutions
Heating, Ventilation and Air Conditioning (HVAC)
- Airflow Through a Perforated Plate
- Blower Impellers
- Convection Coefficients
- Fan Law Calculations
- Fluid Flow in Pipes
- Orifice Flow
- Pipe Sizing Tables: Air, Natural Gas, Water
- Properties of Air
- Psychrometry
- Safety Ventilation
- Saturation Tables
- Solar Radiation
- Steam Pipe Sizing
- Temperature Conversions
Mechanics
- Belt Conveyors
- Critical Speed
- Drill Bits
- Fastener Torque
- Keys and Keyseats
- Line Shaft Sizing
- Moment of Inertia
- Power and Torque
- Roller Chain Sprockets
- Screw Threads
- Shear Keys
- Sleeve Bearing PV Limits
- Spur Gear Calculations
- Stress and Deflection
- -Beams I
- -Columns
- Torsional Deflection of Shafts
- V-Belt Drive Systems
Electricity
- Air Coil Inductor Design
- Electric Motor FLA Ratings
- -Single-Phase AC Motors
- -Three-Phase AC Motors
- Electric Motor Frames
- -NEMA Standard Frames
- -AC Motor Dimensions
- Electrical Enclosure Ratings
- NEMA Starter Dimensions
- Ohm’s Law Calculations
- Wire Tables
- -Copper Wire
- -Aluminum Wire
Materials
- Mechanical Properties of Materials
- Physical Properties of Materials
- Thermal Properties of Materials
- Coefficients of Friction
- Periodic Table of the Elements
- Pipe and Tubing
- -Pipe and Tubing Data
- -Schedule 40 Pipe Data
- Sheet Metal Thickness-Weight Calculator
Structural
- Structural Aluminum Profiles
- -Aluminum Angles – Equal
- -Aluminum Angles – Unequal
- -Aluminum Association Channels
- -Aluminum Standard Channels
- -Aluminum Association I-Beams
Structural Steel Profiles
- -Steel Angles – Equal
- -Steel Angles – Unequal
- -Steel Channels
- -Steel I-Beams (S-Sections)
- -Steel I-Beams (W-Sections)
- -Steel Rectangular Tubing
- -Steel Square Tubing
Note: I also recommend checking out the most advanced electrical, electronics, mathematics, and computer training program I have seen to date: Electrical, Electronics, Mechanical, Mathematics Super Calculation Program
Source: pwr-tools.com/new_pwr-tools/download/
