AVR Microcontroller Calculator
AVR Calculator is a program designed to simplify coding for those working with AVR microcontrollers. It allows you to calculate UART parameters and simplify working with 8 and 16-bit timers in different modes. The AVR Calculator program requires no installation.
It helps you set up TWI (I2C) operation, specify watchdog timer parameters, and more.
Actions performed with the AVR Calculator program can be saved and restored in .txt format.
AVR Calculator Features:
1. Baud Rate Calculator: Calculates UART parameters.
2. Timer Calculator: Works with 8 and 16-bit timers in different modes.
3. TWI Calculator: Working with TWI (I2C).
4. Watchdog Timer Calculator: Watchdog Timer Parameters.
5. FMUL Calculator
6. 32-bit Number Calculator
7. ASCII Calculator: Real number arithmetic, conversions, etc.
fmul-calculator-avr
the-baud-rate-calculator-calculates-uart-parameters
the-timer-calculator-8-bit-16-bit-timers-different-modes
twi-calculator-working-with-twi-i2c
watchdog-timer-calculator-watchdog-timer-parameters
avr-32-bit-number-calculator
avr-ascii-calculator-real-number-arithmetic-conversions
