The most important part is the construction of a functional sample of a Arduino Uno software-defined one transmitter. After agreement with the supervisor and current options, she was elected concept with SI4713 digital circuit for FM band 76-108 MHz. first the point of practical implementation is a block design with the necessary description of the basic radio interface, communication interface, and so on. The complete wiring diagram follows created in the Eagle design together with the printed circuit board. The design is an important criterion for correctly designing impedance matching and tuning the antenna to achieve satisfactory results.
Practically it is a target device designed as a hardware module for the Arduino learning platform. The board also includes a display with display parameters, controls or a transmitting portion with a connector, a fitting member (filter). Finally, it is explained the principle of the control program. The result of the diploma thesis is a functional product – a software defined transmitter, which broadcasts the connected FM audio signal. The control program allows set a wide range of properties to achieve different parameters of the transmitted signal.
SI4713 The entire hardware part is conceived as a shield to the Arduino platform. This module is simply inserted into the development kit board and into its the control microcontroller will record the control program. The main circuit is a digital integrated circuit from Silicon Laboratories SI4713, which communicates with the system via the I2C bus. control and the display of information is secured using the buttons and the display. Output circuit is connected to the matching member and the output filter. Signal source for analog inputs it can be essentially any device. Arduino Uno
The Arduino Uno control program is written in the Arduino development environment and its purpose is to set it up parameters of the SI4713 based on the user manual. They serve it two means – commands and properties. Commands are actions large 1 B. Arguments specify the given command, for example, to set the frequency Enter the 0x30 TX_TUNE_FREQ command and enter the value using the argument frequency. Each command can have up to 7 arguments, the argument is large 1 B. If the argument is 16-bit, divide it into two 8-bit partitions and send it sequentially right behind you. Properties are special parameters that are set after the circuit is started using one command
SI4713 Arduino Uno FM AM Transmitter Schematic
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-26024.zip
Publication date: 2018/05/18 Tags: arduino projects, microcontroller projects
SI4713 Arduino FM-AM Sender Schaltung
Der wichtigste Teil ist der Aufbau eines funktionalen Beispiels eines Arduino Uno Software-definierten Senders. Nach Vereinbarung mit dem Vorgesetzten und aktuellen Optionen wurde sie mit SI4713 Digitalschaltung für FM-Band 76-108 MHz Konzept gewählt. Der praktische Umsetzungspunkt ist zunächst ein Blockdesign mit der notwendigen Beschreibung der Basisfunkschnittstelle, der Kommunikationsschnittstelle und so weiter. Der komplette Schaltplan folgt im Eagle-Design zusammen mit der Leiterplatte. Das Design ist ein wichtiges Kriterium für die korrekte Gestaltung der Impedanzanpassung und Abstimmung der Antenne, um zufriedenstellende Ergebnisse zu erzielen.
Praktisch ist es ein Zielgerät, das als Hardware-Modul für die Arduino-Lernplattform entworfen wurde. Die Platine enthält auch eine Anzeige mit Anzeigeparametern, Steuerungen oder einen Übertragungsabschnitt mit einem Verbinder, einem Passelement (Filter). Abschließend wird das Prinzip des Kontrollprogramms erläutert. Das Ergebnis der Diplomarbeit ist ein funktionales Produkt – ein softwaredefinierter Sender, der das angeschlossene FM-Audiosignal sendet. Das Steuerprogramm ermöglicht die Einstellung einer großen Bandbreite von Eigenschaften, um verschiedene Parameter des übertragenen Signals zu erreichen.
Circuit émetteur FM AM Arduino
La partie la plus importante est la construction d’un échantillon fonctionnel d’un émetteur défini par logiciel Arduino Uno. Après entente avec le superviseur et options actuelles, elle a été élue concept avec circuit numérique SI4713 pour la bande FM 76-108 MHz. tout d’abord, l’implémentation pratique est une conception de blocs avec la description nécessaire de l’interface radio de base, de l’interface de communication, etc. Le schéma de câblage complet suivant est créé dans la conception Eagle avec la carte de circuit imprimé. La conception est un critère important pour concevoir correctement l’adaptation d’impédance et le réglage de l’antenne pour obtenir des résultats satisfaisants.
Il s’agit pratiquement d’un appareil cible conçu comme un module matériel pour la plate-forme d’apprentissage Arduino. La carte comprend également un affichage avec des paramètres d’affichage, des commandes ou une partie d’émission avec un connecteur, un élément d’ajustement (filtre). Enfin, il est expliqué le principe du programme de contrôle. Le résultat de la thèse de diplôme est un produit fonctionnel – un émetteur défini par logiciel, qui diffuse le signal audio FM connecté. Le programme de contrôle permet de définir une large gamme de propriétés pour atteindre différents paramètres du signal transmis
