is this a 4th order low pass filter? i want to build diy 4th order low pass filter for active subwoofer. which can i build. thank you. please provide pdf... Subwoofer Filter Circuit 50..200Hz
here one major issues found in code that, as per the documentation of PT2322 and as my experiance on the same, the ic will not function properly while we apply master volume ten and unit values this way.
https://ibb.co/wLdqB03... PT2322 PT2323 Arduino 5.1 Digital Audio Control Circuit
This is a really good amplifier for powering subwoofers. As you know, biasing the Darlingtons is no easy task. This board did a really good job at doing that, but still, at low to medium volumes, you will get distortion, particularly on piano notes. Hence, I first said that this is really good for subwoofers as the bass is really deep (especially if you use NE5532 Op-amps), and you can’t really hear the distortion with subwoofers.
Also, the EI33 is not sufficient for providing enough power for the really power-hungry output section, and it will become saturated at around 120W RMS of output in bridge mode. So that’s why I changed it with a proper toroidal transformer. But if you are using it in stereo mode, the EI33 will suffice.... Car Amplifier Circuit TIP142 TIP147 200W DC DC TL494 EI33
@gevv:
No you can't get 400w
https://320volt.com/en/400w-amplifikator-n-kanal-2sc5200/
https://320volt.com/en/200w-500w-amplifier-powerful-bass-clear-sound/
https://320volt.com/en/crown-xls-clone-diy/... 2SA1943 2SC5200 200W Amplifier Circuit
Can I get 400 watt mono, if I add two more pair of 2sa1943 and 2sc5200 in this same circuit and I will use 40 0 40 15A, Transformer ?... 2SA1943 2SC5200 200W Amplifier Circuit
Hy My name is Sagheer Ahmad From Pakistan.I like this Project. I need a High Voltage Power Supply. So Please share Resistor Value R23 or R27 Or Transformer Winding Data. i want to make this supply a turn any fixed voltage variable power supply.
'please Reply my Question... 1200W 60V SMPS Circuit UC3844 150Khz
@Sagheer Ahmad:
Hy dear my name Is Sagheer Ahmad. I am from Pakistan.I like this Power Supply Project. you did not add the Top silkscreen of the power supply design to the Winrar file.Please i want to make this supply.... Adjustable power supply
Thank so much bother.. God bless you🙏... 12V to 70V DC DC Converter Circuit SG3525 900W
Hello sir... Is this gerber file 4 layer or 2 layers?? I've try to see the file on jlcpcb it saying 4 layers. Please help... 12V to 70V DC DC Converter Circuit SG3525 900W
Hi, No sales. The files required for the construction of the circuit were shared... LM3915 80 LED Audio Spectrum Analyzer Circuit
Hi, pcb is single layer. ... 12V to 70V DC DC Converter Circuit SG3525 900W
How many layers this pcb bruh? In jlcpcb its detected 4 layers. Is it true??... 12V to 70V DC DC Converter Circuit SG3525 900W
Do you have a purchasable PCB for this project?... LM3915 80 LED Audio Spectrum Analyzer Circuit
Can i take the TLV431 for cut off under 2,0 volts?... Battery Discharge Protection Circuit
here one major issues found in code that, as per the documentation of PT2322 and as my experiance on the same, the ic will not function properly while we apply master volume ten and unit values this way. https://ibb.co/wLdqB03... PT2322 PT2323 Arduino 5.1 Digital Audio Control Circuit
r1, r2... Battery Discharge Protection Circuit
pcbpdf-pcb-region.rar 25hz-250hz-subwoofer-bass-crossover-pcb-bmp.rar... Subwoofer Filter 25Hz 250Hz Bass Crossover Circuit
Hey, I need PDF layout plz.... Subwoofer Filter 25Hz 250Hz Bass Crossover Circuit
Which resistors are the reference resistors?... Battery Discharge Protection Circuit
Hi Can i use 18k instead of 22k resistors?... TDA7294 Amplifier Circuit Small PCB
Hi! Do you have diagram circuit for STAMOS MULTI 195 and GUDE GIS 200? Thank you!... Welding Machine Schematics Service Manual
This is a really good amplifier for powering subwoofers. As you know, biasing the Darlingtons is no easy task. This board did a really good job at doing that, but still, at low to medium volumes, you will get distortion, particularly on piano notes. Hence, I first said that this is really good for subwoofers as the bass is really deep (especially if you use NE5532 Op-amps), and you can’t really hear the distortion with subwoofers. Also, the EI33 is not sufficient for providing enough power for the really power-hungry output section, and it will become saturated at around 120W RMS of output in bridge mode. So that’s why I changed it with a proper toroidal transformer. But if you are using it in stereo mode, the EI33 will suffice.... Car Amplifier Circuit TIP142 TIP147 200W DC DC TL494 EI33
No you can't get 400w https://320volt.com/en/400w-amplifikator-n-kanal-2sc5200/ https://320volt.com/en/200w-500w-amplifier-powerful-bass-clear-sound/ https://320volt.com/en/crown-xls-clone-diy/... 2SA1943 2SC5200 200W Amplifier Circuit
Hy please send me software code for dual volt meter i csahnge line name 1. 2. i need line 1 VGH line 2 VGL thanks .... Dual LCD Voltmeter Ammeter 0.100 VDC 0.10 A DC ATMEGA8
40x1.41= 56.4vdc With a good cooler and fan you won't have any problems.... 2SA1943 2SC5200 200W Amplifier Circuit
Will it be safe and no overheat for 4 ohm subwoofer with 40-0-40 ac transformer?... 2SA1943 2SC5200 200W Amplifier Circuit
Hi, Yes you can use it.... 2SA1943 2SC5200 200W Amplifier Circuit
Ciao, prova le impostazioni predefinite del fusibile... Dual LCD Voltmeter Ammeter 0.100 VDC 0.10 A DC ATMEGA8
Hi, Can we use 40-0-40 ac 10amp transformer.... 2SA1943 2SC5200 200W Amplifier Circuit
Buon giorno, non trovo i fuse bit, e un altra domanda, può misurare tensioni negative? Grazie.... Dual LCD Voltmeter Ammeter 0.100 VDC 0.10 A DC ATMEGA8
Hy My name is Sagheer Ahmad From Pakistan.I like this Project. I need a High Voltage Power Supply. So Please share Resistor Value R23 or R27 Or Transformer Winding Data. i want to make this supply a turn any fixed voltage variable power supply. 'please Reply my Question... 1200W 60V SMPS Circuit UC3844 150Khz
Hi, Replace the 33-ohm resistor with a trimpot... 8-OHM 100W RMS Amplifier 2SC5200
Hello, Install latest version winrar, https://www.rarlab.com/download.htm... SG3525 EI33 200w-600w ATX DC DC Converters Circuits
Hello. Password doesn't work... SG3525 EI33 200w-600w ATX DC DC Converters Circuits
