20Hz 25kHz Subwoofer Amplifier Circuit TDA1514A
| July 9, 2023 Updated
20 Hz to 25 kHz TDA1514 amplifier integrated subwoofer amp used in the cabin floor bass filter TLC272 opamp used symmetrical +-27v supply voltage to feed the olrak opamp zener diode made ​​R12 regulated.
TDA1514A TLC272 20Hz 25kHz RMS 32Watt TDA1514A Aktivbox – This NF-performance amplifier module is equipped with a 230-V power supply equipment and provides 32 W / sinus an 8-ohm speakers. The module is designed for the rear Installation in loudspeakers designed so that a simple way Aktivbox powerful.
For active speakers (with built- AF power amplifier ) there are many uses . Thus, a Active speaker in the musicians’ area as a monitor serve , or audio devices with low Output receive a corresponding Power amplifier . With the here featured amplifier module and a existing 8- Ω speaker system with at least 32 W sine – continuous load may now in a simple way powerful active speaker with very good created technical data in DIY Among the most important technical data a part of the 3-dB bandwidth of 20 Hz to
Subwoofer Amplifier Project
anfi-bass-anfi-filtre-rms-subwofer-tda1514a-tlc272-subwoofer-anfi
25 kHz and low distortion, which in Sheet with max. – 80 dB, typical – 90 dB indicated at full load. The sine continuous output power is the data sheet with 32 W into 8 Ω specified, while a Music power of 42 W is available stands. The block diagram in showing the internal structure of the TDA 1514 A in SIL9P housing.
20Hz 25kHz Subwoofer Amplifier Circuit TDA1514A download:
Published: 2008/06/28 Tags: ,
1 Comment “20Hz 25kHz Subwoofer Amplifier Circuit TDA1514A
    Ultrasonic Distance Meter Circuit LED Display Parking Sensor
    Ultrasonic distance meter, ultrasonic parking sensor and opamp CMOS integrated circuit representation on the board from two ultrasonic receiver circuit with LEDs used and UST-40 UST -40T
    Distance measurement using ultrasound is already widely used. We provide an easy to implement distance measurement and display circuit, is universally applicable. About an LED chain is the distance before a Ultrasonic sensor located opposite stand.
    When one thinks of the convenient “contactless” Measuring distances falls, sure almost every first “radar” a, a distance measuring method since the standard in the Air and Shipping is to distances and To determine speeds. For a short However, distances has in the past 20 years ultrasonic measuring method established that much easier and is to implement cost-effective and also not with high-energy radio waves works.
