Simple Circuits Book a 555 Timer Application
| September 14, 2023 Updated
Talking Electronics Sites previously shared the new book The 200 pieces prepared for transistor circuits I mentioned. Author of this type continues to free.
Many of the circuits simple circuits 555 in the book is set up with very few elements oscillators, timing, LEDs, motor control and you have to practice a lot more
555 timer circuits
555-Circuits-ebook
555 Circuits II LIST OF CONTENTS
Active High Trigger
Active Low Trigger
Alarm Sounds (4 sounds)
Alarm 4-Zone
Amplifier using 555
Animated Display
Audio Frequency Meter
Automatic Curtain Closer
Astable Multivibrator
Basic 555 Oscillators
Battery Charger (voltage doubler)
Bi-Coloured LED
Bike Turning Signal
Bi-Polar LED Driver
Bi-Stable 555
Building the Circuits
Burglar Alarm 4-Zone
Capacitor Charge Pump
Car Lights Flasher – warning flasher
Car Tachometer
Charge Pump
Clark Zapper
Clicks Uneven
Calculator 555 7555
CMOS 555
Constant Current
Continuity Tester
Crossing Lights
Curtain Closer
Dark Detector
Delay – also called a Timer
Delay before turn-on
Dog-Bark Stopper
Doorbell for front door and back door
Dice
Dice to 7-Segment Display
Display – Animated
Divide by 2
Driving A Bi-Coloured LED
Driving A Relay
Driving White LEDs
Duty Cycle 1:1 (50%)
Fade-IN Fade-OUT LEDs
Fading LED
Fastest 555 Oscillator
Flasher
Flashing Indicators
Flashing Railroad Lights
Flip Flop see also
Toggle
Four Alarm Sounds
Frequency Divider
Frequency Meter
Function of each 555 pin
H-Bridge
H-Bridge Push-Pull – high current
H-Bridge with PWM
Headlight Flasher – faulty circuit
Headlight Selector
Hee Haw Siren
Higher Sinking Current
High Frequency 555 Oscillator
How to use the 555
Hysteresis
Improving the output of a 555
Increasing Sinking Current
Increasing Output Push-Pull Current
Inverter 12v to 240v
Inside the 555
Jammer for TV
Kitt Scanner
Knight Rider
Laser Ray Sound
Latch
Latch A Relay
Latch – using transistors
LED Dice
LED Dimmer
LED FX
Light Controlled Screamer Siren
Light Detector
Lights – Traffic Lights
LMC555 CMOS 555
Low Current Timer – 7555 CMOS 555
Low Frequency 555 Oscillator
Low Power 555
Machine Gun
Mark-Space Ratio
Memory Cell see also
Toggle Flip Flop
Mercury Switch Detector – faulty circuit
Metal Detector
Missing Audio Detector
Missing Pulse Detector – faulty circuit
Model Railway Time
Monostable 555
Morse Keyer
Mosquito Repeller
Motor Controller (stepper Motor)
Motor Controller (servo motor)
Motor PWM
Multivibrator – Astable
Music Box
Negative Voltage
Normally Closed Trigger
One-Shot 555
Organ
Phase Control with XR-L555 (low power)
Police Lights 1,2,3
Police Siren
Powering A Project
Pulse Extender
Pulser – 74c14
Push Pull
PWM Controller – FET buffer
PWM – transistor buffer
see also Motor PWM
Railroad Lights (flashing)
Railway Time
Rain Alarm
Ramp Generator
Reaction Timer Game
Replacing 556 with two 555’s
Replacing TTL 555 with CMOS 555
Resistor Colour Codes
Re-triggerable 555
Reversing A Motor
Roulette
Schmitt Trigger
Screamer Siren – Light Controlled
Servo Controller
Servo Tester
Simplest 555 Oscillator
Sinewave Output
Siren 100dB
Solar Tracker – not suitable for 555
Square Wave Oscillator
Stepper Motor Controller
Stun Gun
Substituting a 555 – Part 1
Substituting a 555 – Part 2
Supply (170v) for Nixie Tubes
Switch Debounce
Tachometer
TE555-1 Stepper Motor Controller
TE555-2 Animated Display
TE555-3 4 Alarm Sounds
TE555-4 Dice
TE555-5 LED Fx
Ticking Bomb
Tilt Switch
Timer – 5 seconds
Toggle A Relay
Toggle 555 555 ON/OFF Flip Flop
Touch Switch
Touch ON-OFF
Toy Organ
Traffic Lights
Traffic Lights – 4 way
Transistor Tester
Trigger Timer – 74c14
Turning Signal
TV Remote Control Jammer
Useless Machine
Uneven Clicks
Up/Down Fading LED
Using the 555
VCO (Voltage Controlled Oscillator)
Voltage Doubler see also Battery Charger
Voltage Tripler
Voltage Inverter
Voltage Multiplier x10times
Warning Flasher – car lights flasher
Water Level Detector
Wailing Siren
Zapper (Dr Clark)
Zapper – Voltage Multiplier
Zener Diode Tester
2 Minute Timer – 74c14
3x3x3 Cube
4 Alarm Sounds
4 way Traffic Lights
4-Zone Burglar Alarm
1-10 Minute Auto Turn Off
5 Seconds Delay
10 Minute Timer – 74c14
12v DC to 12v DC Battery Charger
12v DC to 19v DC
12v to 240v Inverter
50% Duty Cycle
100dB Siren
170v Supply for Nixie Tubes
555’s – a list of substitutes
555 Amplifier
555 CMOS version LMC555
555 Kit of Components
555 Pinout
555 Pins – Remembering the pins
555 Mistakes (No-No’s)
555 on 24v
555 Timer Calculator
555 VCO
556 Dual Timer
7555 CMOS Calculator
7555 Low Current Timer (delay)
555-timer-circuits-555-devreleri
Source: talkingelectronics.com/ 555 timer projects alternative link:
Published: 2010/03/16 Tags: , ,
1 Comment “Simple Circuits Book a 555 Timer Application
    Air Core, Toroid Coil Calculator Programs
    The coil has an inductance (expressed in Henry and submultiples – “L”), a ballast to the passage of alternating current (expressed in Ohms – “X”), a resistance to the passage of direct current (“R” – in Ohms) , a factor of merit.
    L ‘inductance is the ability to store electrical energy in an electromagnetic field. The ballast is an electrical resistance element that offers to the passage of an alternating current having a certain frequency. The factor of merit (or quality) expressed with the letter Q is the ratio of the reactance (inductive in this case) and the sum of all the losses associated with the decrease in energy in transit
    Air Core Calculator
