The single channel 200W version of the amplifier shared in the article 400w (2X200w) Transistor Amplifier Circuit was designed as small as possible in PCB size.
The power transistors of the 200W Afi circuit do not require the classic 2SC5200 and 2SA1943 quiescent current adjustment. The amplifier can deliver 100W RMS power with a 4-OHM speaker and a 200W RMS 8-OHM speaker.
Amplifier operating voltage max. 2X50V DC 6A (2X33VAC or 2X36VAC transformers can be used) supply filter capacitors For usable bridge diodes between 4700uf… 10.000uf, ready KBU10M or 4 P600J 6 ampere diodes can be used.
330PF capacitor protects the amplifier from high frequency oscillations. If you cannot find a 330PF, you can use a 270PF capacitor instead.
The author says about the 2SA1015 transistors that counterfeits are a lot on the market. To understand that the transistors are original, it is necessary to measure BETA or hFE with a digital multimeter. The 2SA1015 should show 180 or slightly less in the hFE measurement. 2N5401 can be used instead of 2SA1015, but the leg connections are different, be careful with this, the basin and collector legs should be changed in the PCB assembly (I have experimented with the 2SA733 transistors I have)
2SC5200 and 2SA1943 transistors need to use insulators in the cooler assembly.You can look at the article Heat conduction and insulators for details, the equalization resistors of output transistors 0.33-OHM….
The author said that a cooler can be used for TIP41-TIP42 transistors, but I left a hole for the cooler installation, but you can install 2 pieces of 2mm aluminum strip or a separate small cooler for all of them or you can look at the heat condition.
The 5uH coil must be wide enough to pass into a 10-OHM 1W resistor to be wound 11 rounds of 1mm wire. I used a drill bit.
200W Transistor Amplifier Circuit Diagram
200W Amplifier Test and Voltage Measurements
The source of the circuit is reliable, and since the circuit was made by our readers before, I made the assembly of the materials and went directly to the test.I had a 2X30V transformer and 50W bass and 30W normal speaker cabinet.I could not raise the volume much more than 50% sound quality, power was very good 27-OHM 1W resistor I did not have. instead I used 2 pieces of 56-OHM connected in parallel.
Printed circuit PCB dimensions are 100X49mm and single layer PCB drawing was made with Sprint Layout PCB program.
I used C1 in the upper layer to strengthen the voltage inputs and outputs. If you are going to print PCB at home, do not select C1 when printing.
Note: I added the SMD option for 330PF in PCB Design, but removed it from the drawing to avoid confusion. The 18K SMD resistor in the audio input has been changed to be DIP casing assembly.Finally, I removed the optional SMD filter capacitors, they were already staying away from the supply inputs, and the voltage input lines are very short and the roads are thick.
Finally, when 2SC5200 and 2SA1943 are used for the writer output transistors (2SD1047 (NPN) 2SB817 (PNP)), the max. He says that it can be 2X62V DC, in this case the voltage of the capacitors used must be above 63V and instead of TIP41 TIP42 2SCC2073 (NPN) 2SA940 (PNP) or 2SA1837 (PNP) 2SC4793 (NPN) should be used. I think 2X50V is enough, even if you say I don’t want loud sound, it could be 2X30V
200W Amplifier Power supply and audio connection
200W Amplifier Component List
Transistors
2X 2SC5200
2X 2SA1943
3X A1015
2X TIP41C
2X TIP42C
Resistors
2X 6.8-OHM resistor – 1W (blue, gray, gold)
2X 100-OHM- 1W (brown, black, brown)
2X 10-OHM – 1W (brown, black, black)
270-OHM 1W (red, purple, brown)
56-OHM 1W (Green, blue, black)
27-OHM 1W (red, purple, black)
4X 0.47-OHM 5W or 0.33-OHM 5W stone resistor
820-OHM 1 / 4W (gray, red, brown)
10K – 1 / 4W resistor (brown, black, orange)
330-OHM 1 / 4W (orange, orange, brown)
18K – 1 / 4W (brown, gray, orange)
1K – 1 / 4W (brown, black, red)
Capacitors
100NF (104) 100v
47uF 63v
2.2uF 63V
330pF (331) (ceramic or multilayer)
Diodes
5X 1N4004
Thanks for the feedback @sina
source: videorockola.com
Published: 2021/01/12 Tags: audio amplifier circuits, transistor amplifier
Hi I’ve got a 47-0-47 volts AC transformator. can I use it as the main power Tr?
Hi, 47×1.41= 66.27vdc heat will be high try to limit the voltage with very good cooling or 10 ohm 5w resistor the resistance value is experimental
Tank you .This resistance should be used before regulator or after it?
You’re welcome, Must be connected to DC output
4 2sa1943 and 4 2sc5200 transistors
Would need what kind of voltage ?
I bought this amp years ago.
No information given, maybe 700 watts
Any help is greatly appreciated
Thank you.
