4X50 Watt Bridge Car Amplifier Circuit TDA7560
| July 17, 2023 Updated
Previously, in the article “4x Auto Amplifier Circuits with TDA73XX Series”, I shared the circuit where the TDA7560 IC can be used, but the PCB drawing was double-sided, this circuit PCB drawing is easier to make single-sided.. let me tell you already, the integrated is bridged within itself, in addition, bridging cannot be done..
TDA7560 4X50 Watt quad bridge car radio amplifier
TDA7560 is a breakthrough BCD (Bipolar / CMOS / DMOS) technology class AB audio power amplifier in Flexiwatt 25 package designed for high power car radio. The fully complementary P-Channel/N-Channel output structure allows a rail to rail output voltage swing which, combined with high output current and minimized saturation losses sets new power references in the car-radio field, with unparalleled distortion performances.
TDA7560 test video;
TDA7560 circuit test
tda7560-4x50-watt-quad-bridge-car-radio-amplifier-amfi-devresi
tda7560-amplifier-circuit-oto-amfi-araba-amfisi
tda7560-amplifier-pcb-circuit-oto-amfi-araba-amfisi
Share circuit of the forum members @ferhat8484 Thanks to those who contributed to preparing resources:
Published: 2013/01/16 Tags: ,
8 Comments “4X50 Watt Bridge Car Amplifier Circuit TDA7560
    Symmetrical Power Supply Circuits
    Symmetrical power resources tone control , etc. preamf . To run such circuits or different circuits , you can use in experiments . The most popular circuits used , positive and negative regulator IC based on the manufacturer’s drawings were made according to standard schemes , but do not forget to check the PCB drawing
    LM317 (positive regulator ) and LM337 ( negative regulator )
    4X50W Brücke Auto Verstärker Schaltung TDA7560
    Zuvor, “TDA73XX Serie mit 4x Auto-Verstärker-Schaltungen” Artikel TDA7560 integriert kann in der Schaltung verwendet werden, die ich geteilt habe, aber die PCB Zeichnung doppelseitig Dies war entwaffnet PCB Zeichnung einseitig leichter gemacht .. bereits lassen Sie mich sagen, integrieren in ihre eigenen überbrückte zusätzliche Überbrückung getan.
    TDA7560 4X50 Watt Quad-Brücke Autoradio-Verstärker
    TDA7560 ist ein bahnbrechender BCD (Bipolar / CMOS / DMOS) Audio-Leistungsverstärker der Klasse AB im Flexiwatt 25-Gehäuse für Hochleistungs-Autoradios. Die vollständig komplementäre P-Kanal / N-Kanal-Ausgangsstruktur ermöglicht einen Ausgangsspannungshub zwischen Schiene und Schiene, der in Verbindung mit hohem Ausgangsstrom und minimierten Sättigungsverlusten neue Leistungsreferenzen im Autoradiofeld mit beispiellosen Verzerrungsleistungen setzt.
    TDA7560-Schaltungstest
  3. Christopher QuadrosChristopher Quadros
    Hi the file dosent exist in the page
  4. Christopher QuadrosChristopher Quadros
    Please check if the file is there
