According to the size of the force is quite a popular TDA2822M amplifier IC is used in computer applications, as well as headphone amp seslendirmesinin connection according to the shape of the stereo or bridge connection with single channel can give higher audio.
The author used as a headphone amplifier 4 ohm 8 ohm or 32ohm speaker kullaklıklar says that good results with high-impedance headphones (100 Ohm, 600 Ohm) talks about the perfect functioning of the circuit, but with the sound level is lower than the
TDA2822M amplifier circuit to 9v.work with connection diagram DC 15v single-source from the DC input socket on the F1 appearing on the sogorta pin socket. On a 6.3 mm jack input socket on the PCB. Note: this circuit is being used in the model are different … TDA2822 TDA2822M
source: faxter.es/Proyectos/Pr05DistribuidorparaauricularesDAU/tabid/109/Default.aspx alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-21913.zip
LDR and Transistor Automatic Light-Dark Switch Project
Light, dark Switch circuit operation to circuit is located on the DipSwitch 5 number must be open. 1 and 2, 3 and 4 are closed while the circuit connected to the relay output device the light key (bright environments. If the device stops the dark environment.) It is used in. 1 and 2, 3 and 4 open while the circuit connected to the relay output of the device in the dark key (dark is executed. Bright environment the device stops.) It is used in.
