TA8210 based on the circuit input in addition to the mix, there mic mp3 player can be connected circuit with 12 volts works only source fed mixer circuit used in the opamp NE5532 Feed dredging simple with regula made instead L7805 Regulator integrated use more healthy quality leads 🙂
Also made with TA8210 amp circuit also has a somewhat simpler
Source: picfun.com/equipj46.html
Guitar Amplifier Input Mixer with TA8210
Published: 2008/06/14 Tags: audio amplifier circuits, ic amplifier
20 Amps 24 Volt Adjustable Regulated Power Supply Circuit L200
Current adjustable L200 voltage regulator integrated circuit based on the output of the power amplifier integrated with 6 2n3005 output voltage can be adjusted for 13.8 volts at 20 amps determined
Circuit current guard is there over-current or short circuit protection is undergoing Yucca high that it is difficult to relay used protection circuit CA3140 opamp based on the 100k potentiometer calibration with 10k potentiometer with a current limit can be adjusted separately sprint laout prepared by the PCB file there
L200 Power Supply Circuit
