Micro-Electronica product areas owned by the user that sent the company projects in various fields has many applications with source code in some simulations, there proteus isis.
Mikropascal Micro C project
FPGA programmer with PIC18F4550 on USB, USB PS2 Keyboard Project, PS2 Mouse Project, PS2 Keyboard Project, Accelerometer-based Joystick with USB support, uM-FPU V3.1 Examples, I2C LCD (real), Adc Display, SMS type keypad and usart data receiver, Serial Communication, TFTP Server Fat32, TFtp Server, Fat16, Long filenames, TFTP Server (Fat16, short filenames), Telnet to RS232 interface, PIC command line editor, Small Telephone Exchange, StringUtils (Unit), PascalFunctions (Unit)
Alarm ctl with ethernet, gsm modem, onewire, PS2 Laser Mouse Interface, Using Interupts to Display Time, 1-Wire Library, PIC REAL TIME CLOCK, LCD4 OPTIMUM for mikroBasic, mikroPascal, and mikroC, Soft Uart for P12, dsPIC30F6014 and accelerometer card Example, UDP Bootloader for P18 MCU with ENC28J60, I2C LCD, Playstation 2 Controller with Mikrobasic, One Wire NetWork, GLCD Midi Controller P18F452, 4D µLCD demo + library, Midi Controller PIC16F877A, PRINT_DEC FUNCTION project, Accurate Extended Event Timer (48MHz) project, Manchester signals decoding project – mikroBasic
Print filenames on GLCD project, Manchester signals decoding project – mikroPascal, LCD Format LongInt, Gear Display Project, 18F2550 USB-HID 8- 50Hz PWM SERVO CONTROLLER project, Serial Stepper Controller, Time And Temperature project using Dallas DS1629, Serial LCD Project, Tachometer project, Dual Pwm, 8 DECADE COUNTER, Ultrabright flashlight project, Bi Directional DC motor Control project, RTC2 DS 1307 (Unit), RTC_PCF8583P (Unit), Debug (Unit), EepromVariable (Unit), BitUtils (Unit)
Fat32, IDE, Fat16 Dir LFN, Fat16 Dir , COS – Cooperative Operating System, Mem Manager (unit), LCD 4Bits (16/20 chars, 2/4 rows), Usart Receiver, USB CDC (unit) Rc6 Decoder, Rc5 Decoder, DS1820, , RS232 Baudrate timer, DTMF with EEPROM Storage, DTMF decoder with character storage in RAM, usb hid, LCD LED, Joystick Conversion, RS485 complete library for PIC18 family, 5 Axis 32 Button Joystick Controller, Simple Game Die – With Sound,12f683 3wrd viMeter , Digital Security Lock, Temperature RF Link, Timer0 Example Simple 1, Stepper Motor Control GUI, AC voltage, corrient, watt, angle fase on lcd, Ultrasonic distance to voltage converter with DAC
trf2.4 rf communication, I2c slave and master Communication, Lotery baloto random number, Ultrasonic distance to voltage converter, 8 Serial servo-controller , Lcd 8-bit – mikroBasic, mikroPascal and mikroC, GLCD GPS Decoder, GPS Decoder, jBox Alert, Serial Communication using USART, Home Automation System Using User Interface, Custom LCD Lib, Thermostat with P16F628A, PIC based timer, Touch dimmer, LCD 4-bits (unit), LCD 3wr mikroC coded
Published: 2010/10/06 Tags: dspic projects, microchip projects, microcontroller projects, pic16f84 projects, pic16f877 projects, pwm circuits
Atmega16 Touchscreen Project TFT App AVR GCC ILI9325
Touch TFT application based on ATMega16 processor used in the 16 MHz frequency drives and ILI9325 OTM3225, source C code (AVR GCC)’s.
