Lucid dreaming quite an interesting topic “Dream On” as a phrase is. Person’s dream to realize that dream and to control a lot of people aware of this incident but no widespread throughout the world even in the dream is to understand its electronic circuits (Lucid dreaming circuits) whether engaged there.
In fact the whole business the man himself to concentrate on this idea, but the dream is very beneficial external effects for immediate recall if that’s why I designed several circuits
Lucid Dreaming mounted circuit-face;
cre.ations.net sitesinde “Lucid Dreaming Mask” yazısında yazar bu iş için yaptığı bir devreyi paylaşmış devrede pic 16f84 kullanılmış iki adet led göz hizasında rüya anında ışık veriyor kişi rüyada olduğunu anlıyor >> kırmızı ışık / rüyadasın / kontrol sende 🙂
Also with the time setting for this job if you have an mp3 player, a lot of rooms available on the web about this kind of people’s writings, has developed varieties tactics.
Software prepared by the assembly of the circuit as a simple set of phenolic hole.
Password: 320volt.com
Published: 2010/08/29 Tags: microchip projects, microcontroller projects
Double Melody Door Bell Circuit KS5814
In this article, double-melodic ring made with KS5814 integrated circuit will tell you. Integrated KS5814, in which two principal melody, produced by SAMSUNG company, is a 14-pin integrated. In that the logic operation of the circuit;
1 button is pressed out a melody similar to bird sounds from the speaker. 1 and 2 buttons simultaneously while pressing the home phone melody sounds similar to the sound.
Moreover, the circuit of resistors and capacitors tones can be adjusted by changing the values. Circuit used a variety of purposes.
Door Bell Circuit
