LM1875 22W Stereo Amplifier Circuit Tone Controlled
| July 19, 2023 Updated
A lot 5.1 sound system used in the quality of an amplifier IC lm1875 circuit two used this integrated shape and leg connections TDA2030A is the same amp for the supply rectifier and filter capacitor the same pcb on the tone control (bass, treble) for what 5532 op-amp used in addition to called bypass feature has low noise opamp amplifies the tone 15volt zeners achieved by the supply the circuit is working with symmetrical voltage transformer to be used must be 2x2amp 2x18v
Tone Controlled LM1875 Stereo Amplifier Project
lm1875-22w
Consider low power, simple circuit, with the best sound control (some people like to have a good control of the sound level), low cost, DIY easy I think positioned between 20W ~ 30W Well, it compares a lot to the network circuit, the final choice of the power amplifier IC LM1875 circuit
Too many people on the network brought it relatively low-cost TDA2030, and the market seems to have handed in a lot of the words rubbed off by the TDA2030 re Remark into LM1875 to sell, because the difference is large, be careful when you buy yourself a little , is probably too low there is a problem in the specification for TDA2030 is almost, but not a bad idea if you want to try, pin fully compatible, can be directly replaced, but be careful, its low operating voltage, TDA2030 when used with a low voltage transformer, 12-0-12 V AC output transformer for instance.
source digitw.com LM1875 22Watt Stereo Amplifier Circuit Tone Controlled schematic PCB files alternative link:
Published: 2009/04/19 Tags: ,
1 Comment “LM1875 22W Stereo Amplifier Circuit Tone Controlled
    Speaker Protected LM3886TF Stereo Amplifier Circuit
    LM3886TF Amplifier circuit pretty a quality PCB design has to supply the diode bridge and filter on the capacity also for the volume control stereo 100k potentiometer attached LM3886 inputs and outputs used in this opamp NE5532 instead ad827 used opamp beslemesiç the same pcb on the 7815 and 7915 fixed regulator IC supply with available the coils are given the values ​​in the output section
    LM3886TF plastic sheath used in practice, but the sound quality is a bit low power metal sheath is said to be better than you can use instead LM3886T performance would be better if you can connect to the cooler fan
