I generally various trials also material loss data, but this business of entertainment into a Getian those have high current, high voltage capacitors with resistors, LEDs, transistors, a lot like the electronics swings are burning 🙂 a computer motherboard used in the ram burned has interesting displays ..
Electronic Material Burn
Published: 2010/08/06 Tags: technical video
PIC16F877 PFC8583 Alarm Clock Circuit PicBasic
The time for the establishment of : press the SET button . 00 in square brackets, leaving the MODE key to skip to the hour setting . After setting the time and order of minutes with the MODE key Month-Day and the Year Make settings . Exit the setting mode by pressing the SET button at the end .
