RGB LEDs long ago lighting, including advertising signs animations etc. .. a lot like the application is being used colors can be checked wide range of application, but naturally single-color LEDs according to prices higher .. Honda Fit model, the RGB LED fault applications in the car, a different air 🙂 has added SMD RGB LEDs are used in practice to control the op amp mosfet driver circuit consists of a simple drawing of circuit diagram pcb there ..
Source: drive2.ru
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16191.zip
Published: 2011/09/17 Tags: analog circuits projects, led projects, simple circuit projects
100A TIG Welding Circuit IGBT UC3845 IRG4PC50U ETD59
SMPS (switch mode power supply) electronic welding machine circuit UC3845 control integrated based on the power transformer for the ETD59 used integrated 6 from exit smallest drive transformer coupled this transformer at the output of the IRG4PC50 the (600volt 27amp’s) IGBT’s. Instead of providing ETD59 supply out of the system with low-power SMPS circuit TOP224Y used. Operating current 3 mm by 100 authors mention that the electrodes have been used …
