Simple DSPIC Experiment Development Board
| July 8, 2023 Updated
Beginner level LEDs, buttons, analog input, 24Cxx EEPROM and serial communication with the PC I did try a little experiment where you can make your own set. Wishing to be helpful. Simple DSPIC Development Board
Try this with a set of tiny LEDs, buttons, analog input, read and write 24Cxx EEPROM, serial communication with the PC experiments. PICKIT2 as programmer, I’m using dsPIC dspıc33fj256gp506 in as.
DSPIC Board
dspic_deneme-150x150
LEDs: D0 and D7 connected to
Buttons: B0 to B4 bound
Pots: AN5 and AN16 dependent
24Cxx: SCL1 and connected to sda1
Serial communication module is connected to UART2. The circuit diagram is drawn with Altium Designer 6.7
DSPIC Development Board Circuit Diagram
dspic-simple-test-board-schematic-diagram
DSPIC Development Board PCB schematic files:
Published: 2008/04/22 Tags: ,
1 Comment “Simple DSPIC Experiment Development Board
    JFET Compressor Circuit
    Compressor Circuit -Ratio-Threshold-Attack and Release controls Out Level bypass feature ensures that there is a 9 volt battery works with sprint circuit layout prepared by PCBs
