AVR900 AVR USB programmer a simple design there more complex but ATmega8 and a few passive components with the established circuit only PonyProg program is working with insurance and program settings as illustrated illustrated supported integrated list but no PonyProg on the Atmel AVR microcontrollers most of the program the XP and XP Vista Seven 32bit 64bit drivers there .. atmel knows better than dealing with the series .. PCB layout drawings prepared by the sprint in addition to the AVR-DIP socket circuit converter atmel programmer with very different PCBs have used in drawing. Before you can use the USB AVR ATmega8 microcontroller programmer circuit “is usb_programmer_av-910.hex” file needed to install
Source: tehnari.ru/f115/t71649/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19927.zip
Published: 2012/11/07 Tags: programmer circuit
Simple Sounder Alarm Circuit With 555
A simple alarm circuit but Mr. deterrent siren voice of the author would not last 🙂 circuits infrared transmitter and as a receiver consists of two parts transmitter circuit also 555 integrated with a controlled IR LEDs have a (tv remote control used in) LED signals sent by other circuits as well TSOP (38kHz or at 36kHz) signal reaches the receiver cut starts to work as soon as the siren siren plowed with TIP120 transistor to stop the alarm does not sound quite high-energize the circuit required
AVR910 USB-Programmiergerät
AVR900 AVR USB-Programmierer ein einfacher Entwurf dort komplexer, aber ATmega8 und ein paar passive Komponenten mit der etablierten Schaltung nur PonyProg-Programm arbeitet mit Versicherungen und Programmeinstellungen wie dargestellt unterstützt integrierte Liste, aber keine PonyProg auf den Atmel AVR-Mikrocontroller die meisten des Programms XP und XP Vista Seven 32bit 64bit Treiber dort .. atmel weiß es besser als mit der Serie zu tun .. PCB Layout Zeichnungen von der Sprint zusätzlich zu den AVR-DIP Socket-Stromrichter-Konverter atmel Programmierer mit sehr unterschiedlichen Leiterplatten vorbereitet haben in Zeichnung verwendet. Bevor Sie die USB AVR ATmega8 Mikrocontroller-Programmierschaltung verwenden können, ist die Datei “usb_programmer_av-910.hex” für die Installation erforderlich
