ARM7 processor great interest in advanced applications on the web is spreading slowly. Indicative ds3234s based on ARM7 clock circuit and if at91sam7s64 “OLEDs” LCD alternative material called
AT91SAM7S64 Clock Circuit
What is Oled? Organic LED (light emitting diode)
Kodak is a technology developed by the company. OLEDs are mostly used for flat screen. As an alternative to LCD technology are presented. In normal operation, low energy consumption, thinner and lighter thanks to the use of mobile phones has become widespread recently. Once they lose their brightness is criticized as is. And is developing a promising technology. Light-emitting diodes (LEDs) last type of family “Organic Light Emitting Device” or “Organic Light Emitting Diode” an acronym stands with mine. “Organic Electroluminescent Device” (OEL) is called. Typically, two electrical contacts (electrodes) and the rest of the organic thin film light-emitting layer consists of a series. OLEDs low molecular weight organic materials (SM-OLED) or polymer-based material (PLED, LEP) occurs. LCDs with different layers and the Fed ‘s OLEDs Unlike monolithic (single layer) d up. Coated on the other, because each layer during construction so as to be integrally produced.
Source: http://code.google.com/p/arm7-oled-clock/ ARM7 Clock Circuit alternative link:
Published: 2010/05/18 Tags: arm project, microcontroller projects
Atmega8 Programmable Controller Board Electronic PLC Circuit
Atmega8 microcontroller connected computer which functions as a PLC control board, but of course does not have a very advanced feature that will give the successful implementation feyza resources shared on üstekik
