Servo Motor Control 74HCT240 With Simple Bug Robot
| Updated on August 3, 2019
bug robot in the robot’s body outside the structure looks simple but cute main ingredients 1 PCs 1 PCs 74HCT240 IC and servo motor, the rest is looking so good, how much labor a work of care. 4 pieces of 1 .5V batteries in series to run the robot by connecting (6v) used. No battery or standing until the Super features stops leading up to a robot insect:)
Source: instructables.com/id/How-to-build-the-one-motor-walker alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18428.zip
Publication date: 2012/01/26 Tags: ,
2 Comments “Servo Motor Control 74HCT240 With Simple Bug Robot
    Regulated Power Supply 0-30 Volt 0-5A 2N3772 TL082
    Elektor the number given in the magazine’s old modified version of the adjustable power supply circuit .. 0 0 5 between 30v voltage and current settings can be made. Control solid TL082 op amp used in the output stage has the power transistor 2N3772 60 volts 30 amps. In addition, the circuit’s voltage and amperage display this circuit based on Atmel ATmega8 microcontroller on the LCD is showing any interest in LCM 1602.
    Bugroboter im Körper des Roboters außerhalb der Struktur sieht einfach aus, aber niedlich Hauptzutaten 1 PC 1 PC 74HCT240 IC und Servomotor, der Rest sieht so gut aus, wie viel Arbeit eine Arbeit der Pflege ist. 4 Stück 1,5V-Batterien in Reihe zum Betrieb des Roboters durch Anschließen (6V) verwendet. Keine Batterie oder Standby, bis die Super-Funktionen aufhören, zu einem Roboterinsekt zu führen 🙂
