If Wifi Router design gives you hands to strengthen domain to upper antenna can be installed with a good view over workmanship without breaking your Router can be more effective
First off equipment may interfere there for the warranty canceled Note that this transaction line and the supply connections of the structure without the new WiFi antenna to attach SMA connector on a small soldering process have shorted one careful not to. summary instead of the original antenna SMA connector is placed disassembled and can be attached to the antenna connector on the desired
Original Antenna Connection
Modified Antenna Connection
Source: postcogito.org
Publication date: 2008/10/05 Tags: simple circuit projects
8051 ADC0808 Lcd Display Voltmeter
ADC0808 analog / digital converter of the 8 analog inputs (IN0-IN7) and 8-bit digital output (OUT0-OUT7) are available. Entries will be transferred to the digital output of the converter which converted to 3-bit ADD, ADD B, and C address ADD is decided according to the tips. ADC0808 to run the ADC clock (Clock) at the end of about 10 KHz-1280 KHz frequency values of the hour mark, which should be applied. VREF (+) terminal of the maximum amplitude of the analog signal to be sampled Vref (-) to indicate the minimum value of the signal to be sampled is used for. Applications Vref (-) usually bağlanır.start soil, OE (Output Enable) and the EOC (End of Conversion) are end-end control of the ADC0808.
8051 Voltmeter Schematic
