Earlier laser printer PCB output took coated paper and supplied with the printed circuit board in preparing Yucel Basic brother’s prepared a letter (Iron and Easy Printing Circuit Board (PCB) Preparation) I shared where you can watch videos or still with the same method of printed circuit boards is preparing process how to do video better You can understand
Initially suitably cut to the size of the drawing pcb copper plaque (phenolic) are heated with iron on a4 paper konulup whereby a short-term plaque toner transferred by ironing.
Ironing PCB Using Laser Toner Transfer
Then transferred from the laser printer on glossy paper cut according to a plaque pcb drawing board with a plaque is placed on each side until coated paper carefully plaque adheres to ütüleniy
Ironing operation after a basin of warm water and coated paper softened it may take some time 5 .10 minutes, coated paper softens after rough sections manually remainder is the toothbrush to be cleaned with started the latest soapy water again and cleaning is done after that etching…
Published: 2009/11/24 Tags: technical video
Microchip Examples Switch Timing Circuits
Microchip pic12cxxx key, timing circuits cog of the PIC12C508 based on the c series instead F series, available in the most simple circuits in some schemes no other software information thanks schemas can be used with all circuits, software assembly prepared with a detailed description (in English) and flow diagram There microchip company sample applications.
Between the circuit’s very simple to understand, especially for people who are new to pic programming a useful resource.
PIC Micro Key, Switch circuits
