Texas Instruments TI the TINA-a useful application of SPICE-based Analog simulation program. The program is available in a wide range of special library and Texas instruments (new release added National Semiconductor opamps) schematic symbol editor hundreds of example application circuit, has also a lot of property visually etc detailed user manual.
In a way, a program to prepare the schema appropriate for the simulation, at least visually, drawing is different than other programs, coloured schematic:)
TINA-TI the TINA simulator program Texas instruments company specially prepared according to the features of the free version of this, but a lot less than the TINA programme in practice, we will see
According to the established circuit circuit Simulator, according to the calculation, the result of the selected vehicle identifications, etc. gives the values so you don’t run as system, for example, in proteus isis; you set up the “Analysis” menu “ERC” circuit (electric rules check) you run the tool lists the results.
TINA-TI Circuit Simulator general characteristics;
Schematic entry and editing
Auto / Manual wire routing and drag support
Devices such as standard schematic symbols
Creating sub-circuits
BOM, Bus, Integrated, Net List Editor
For arbitrary waveform excitation Editor
Schematic Symbol Editor
Analysis Features;
Max. Macro external nodes and the number of nodes in
DC, AC, Transient, Digital, Mixed-mode simulation
Components and number of models
Group Delay
parameter Sweep
Analysis of Direct Net list
Fourier Analysis (harmonic)
Monte Carlo, worst case
Parameter stepping number of parameters
Plotting Properties;
Scale Diagram
multi-Axis
Diagrams drawing tools to improve
Post processing tools
Virtual Instruments
XY Recorder, Oscilloscope, Generator, Multimeter, Signal Analysis / Function Bode Plotter
You can download from the Spice simulator program, TINA-TI http://www.ti.com/tool/tina-ti
Published: 2014/05/06 Tags: electronics software tools
Orangutan SV-328 with Modular Robot Obstacle Detection Project
Obstacle Sensing Robot based on the SV-328 control module circuit Orangutan Orangutan SV-328 is a module that you have internal engine driver Atmel microcontroller, ATmega328P (Toshiba TB6612FNG) can be connected to two DC motor output power 1 .2A max. Peak 3 amps.
Kostenlose elektronische Schaltung Simulator Pspice
Texas Instruments TI-die TINA-eine nützliche Anwendung von SPICE-based Analog simulation program. Das Programm ist erhältlich in einer breiten Palette von speziellen library und Texas instruments (neue Version Hinzugefügt National Semiconductor opamps) schematic symbol editor Hunderte von Beispiel-Anwendung Schaltung, hat auch eine Menge von Eigentum, visuell etc ausführliche Bedienungsanleitung.
