Spy circuit consists of 3 sections there are about 30 pieces transmitter circuit is more complex, but in most circuits modified for reinforcement, additions fm transmitter varieties has been described
Market located in the library known as the FM BUG popular video circuit operation
note All circuits should be used for experimental purposes only and should not be used for any covert activities.
source: talkingelectronics.com/projects/Spy%20Circuits/SpyCircuits-1.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-21300.zip
Transistor Tone Control Circuit and TDA2030 Amplifier
BTJ tone control circuit transistor (BC547) based on mono, stereo preamplifier PCB drawings are also made with solid is in addition TDA2030A Application, 2x15W there. The only source on the operating voltage of the control circuit 12v DC 18v DC but also said it will work with
Senderschaltungen
Spion Schaltung besteht aus 3 Abschnitten gibt es etwa 30 Stück spy Sender Schaltung ist komplexer, aber in den meisten Schaltungen für die Verstärkung modifiziert, Ergänzungen fm Sender Sorten wurde beschrieben
Markt in der Bibliothek bekannt als der FM BUG populäre Video-Schaltung-Betrieb
