TQFP32 in integrated circuits do not require soldering, especially for microcontroller projects, going to work is a handy TQFP32 DIP32 very good craftsmanship In handmade converter pcb solder after filling up with left, right bars soldered onto the sections. In order to facilitate the placement of the chip, the chip will form part of the cut.
In addition to a thick piece of paper pasting onto the pcb integrated onto the chip part of the pcb to secure the plate vidalanıyor. Vidalanıp is used to track when the label for the enumeration of compression adapter is ready for use.
DIP32 adapter to pcb artwork crafted with sprint layout TQFP32. lay to open files with the extension http://www.abacom-online.de/uk/html/dateien/demos/viewlayout50.exe
Source: we.easyelectronics.ru/HomeTech/tqfp32—dip32-perehodnik-dlya-maketirovaniya.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19210.zip
Published: 2012/07/12 Tags: avr development board
Line Following Robot Circuit PIC12F508 MC68HC908QB8
Line following robot project, control of MC68HC908QB8 and PIC12F508 microcontrollers. Motor drive circuit used the L298. The system is complicated and cumbersome, but there’s a different robot projects useful sections PIC12F508-American SFH506-36 IR receiver solid (Infra Red Proximity Detector uses Sharp 38 or 40 kHz IRM) IRE5 sensor solid power supply regulated etc. is a good example of all the source codes also in MC68HC908QB8 and schematic, pcb drawings.
