Solid State Tesla Coil Project TL494 PWM High-Voltage
| July 19, 2023 Updated
TL494 PWM control integrated with the high-voltage applications drive on the floor STW20NB50 MOSFETs used transformer windings information oscilloscope measurements details given me and most of us practice a project that known output transformer is very expensive but the MOSFETs and driver section quite strong other SMPS applications can be useful or less can give you ideas
tl494-yuksek-voltaj-kontrol-devresi-smps-pwm-150x150 stw20nb50-tl494-mosfet-surucu-kati-150x150
Tesla Coil Project Test
source : capturedlightning.org solid state tesla coil schematic solid state tesla coil notes etc. files alternative link:
Published: 2009/05/16 Tags: , , , , ,
1 Comment “Solid State Tesla Coil Project TL494 PWM High-Voltage
    8051 SRF04 Ultrasonic Distance Meter Circuit
    8051 srf04 ultrasonic distance measurement application also contains information about the different controllers and this information can be useful for applications
    8051 microcontroller distance measurement using ultrasonic transceiver done. Studies, using microcontrollers 8051 with the help of ultrasonic distance measurement includes the transceiver. A system ultrasonic transceivers, LCD et al 8051 microcontroller is used.
    Before initiating operation of the system used in the system of the working principle of the ultrasonic transceiver is deemed useful to give a brief. authors :Murat FETTAHOGLU Faruk YILDIRIM
    SRF04 Ultrasonic Transceiver
