Integration with the firm produced the Tinyswitch TNY264 IC made with 5 volt smps circuit 2.5 w all the details (transformer information (efd cores), oscilloscope measurements of materials, construction, and testing stages, etc.) is transferred to the application report Switch mode power supply
Low profile offline SMPS switch mode power supply
Exhibitor: Weng Hoe Wong Joel Supervisor: Richard Cocks – The aim of this project is to produce a low cost Switch Mode Power Supply (SMPS) to power low energy embedded products. The module should be able to handle a wide range of input voltages and produce a steady output at 3 or 5 volts. In addition, the unit must produce power from 500mW to 2.5W with a maximum component height of 12.5mm.
With the completion of this project, I hope that the switch mode power supply can provide highly efficient power conversion in several countries. As the module is design to handle a universal input voltage range, this goal can be achieve.
The objectives of this project have been met as the final product has fulfilled all the specified parameters. However, if I were given a chance to re-design the power supply, I would use a masked PCB so that I can place the components closer to each other. That way, the size of the power supply will be further reduce. In addition, I would like to have multiple voltage outputs (by introducing more secondary windings) to improve the product’s functionality.
Source: http://www.itee.uq.edu.au/~engg4801/ Alternative link:
Published: 2011/01/12 Tags: power electronic projects, smps circuits, smps projects, smps schematic
Active Electronic Load Circuit ATmega88 100w Dummy Load
Power electronics for power tests after a period of difficulty in trying to use the lamp aşlıyor and often what you crave is easier to set up a variety of cargo systems work resources.
A variety of power sources, test circuit only used Kenwood, based on electronic load circuit transistor opamplar atmega88 micro-controller based on the lcd display can be set in the advanced version of the load circuit of power 100w 2 potentiometer precision can be set on the circuit.
