TDA8571J even in the car stereo 200w … 300w sold as cheap car amplifiers used in advanced integrated amplifier operating voltage of 6 volts DC …. 18volt dc circuit is established with very few passive components.
TDA8571J 4×40 W BTL quad car radio power amplifier
The TDA8571J is a integrated class-B output amplifier contained in a 23-lead Single-In-Line (SIL) plastic power package. It contains four amplifiers in a BTL configuration, each with a gain of 34 dB. The output power is 4×40 Watt (EIAJ) into a 4 W load. Electrostatic discharge protection Load dump protection Thermally protected
Note: If the circuit is fully regulated power supply or smps (pc atx etc.) If you will be running with the + 12v line connected you can use instead of 1 piece 8 2200uf capacitor
Source: wojio.b4.pl/wzm445.htm
Published: 2012/08/05 Tags: audio amplifier circuits, ic amplifier
Switch Mode Power Supply Transformer Winding
What should lie so fast an intermediate transformer wound in our country SMPS 10 chinese necessary for the production of the song, I thought you might trafor .. almost all the countries of China SMPS, buy an adapter, even assuming that this rate is considered low by them 🙂
