TDA8138 Two Channel Regulator Circuit PCB printed circuit and schematic drawing of TDA8138 datasheet application prepared with eagle cad electronic drawing program. I used to wonder why they wouldn’t do this type of multi-output IC from time to time, but it wasn’t very popular or it didn’t come across to me..
TDA8138 features; Output current 1a both output short circuit protection, thermal protection. The TDA8138 is a monolithic double positive voltage regulator designed to provide constant precision output voltages of 5.1V and 12V at currents up to 1A.
An internal reset circuit generates a reset pulse when output 1 drops below the regulated voltage value (TDA8138 and TDA8138B ). Can be disabled with TTL input (TDA8138 and TDA8138A ) Short circuit and thermal protections are included in all versions.
TDA8138 5V 12V Fix
TDA8138 Two Channel Multi Regulator Circuit 5V 12V schematic PCB files
Published: 2009/02/15 Tags: power electronic projects, power supply circuit, power supply project
Brenner 9 USB PICmicro Programmer PIC18F2550
Brenner 9 had shared with the new version of sprut. usb programmer circuit for PIC and dsPIC series of shared supports advanced (pıc18fxxjxx, PIC24 dspıc33) circuit again based on PIC18F2550
Also in addition to Brenner 8 3.3 9 volt adapter circuit diagram provided with the appliance can be programmed with eight in advanced integrated
