TDA7375 35w per channel with 4 Ω speaker power can give. The Amplifier project has two versions one single integrated stereo 2 × 35 watts while the other two circuits on a single printed circuit TDA7375 4 × 35 watts able to work with a single source supply can use in your car. PCB files, PDFs and protel format.
In addition to the various ways of integrating’s 4x17W or 2 +1 if you like you can use the TDA7375 datasheet file as given in the diagram.
TDA7375 Amplifier Circuit
TDA7375 dual quad power car amplifier
Amplifier Circuit pcb, schematic Alternative link:
Stereo 35W Amplifier Circuit TDA7375
MSP430 Application Code LCD library Nokia5110
Nokia 5110 LCD with MSP430 microcontroller needed to use the library and MSP430 sample application code 6 x 8 font files. Codes prepared by the C language.
main.c, msp430\nokia_5110.c, msp430\nokia_5110.h, nokia5110.ewd, nokia5110.ewp, bmp_pixel.h, nokia5110.d43, msp430\Debug\Obj\main.r43, msp430\Debug\Obj\nokia5110.pbd, msp430\Debug\Obj\nokia_5110.r43, english_6x8_pixel.h chinese_string_pixel.h
