TDA7294 Stereo Amplifier Circuit Of Controlled Loudspeaker-Protected Tone
| August 4, 2019 Updated
Hi guys, I used the new project again with proven performance, sound, price TDA7294 an amplifier IC. This project, in addition to double check before I share tons of “delayed and Led Excitation Speaker DC protection circuit TDA7294 Stereo” and “2X100” projects, we can say that a combination of amplifier circuit (when the minor detail differences.)
Diode bridge rectifier circuit is required for the feed, filter capacitors, the speaker protection circuit and volume, bass, treble tone control circuit when the psychic has additional settings for the card to connect the output of the power supply transformer circuit is designed as insurance, the filter Board.
tda7294-stereo-anfi-baglanti-semasi-r
High current lines (speaker outputs + v-v supply lines) should be covered with solder.
Use transformer; 4-ohm speakers to 8 ohm speaker 2X24V 2X18V for AC AC suggest, financial standpoint 250W at home enough.
Speaker protection circuit is working with additional resources without main power supply 12v traforu made by operating voltage regulated through but one storey with this floor AC connection cable to the PCB where the need is more clearly understood the connection diagram below. In fact, double layer PCB with printed circuit board can make smaller but a very amateur at his home circuit can be very troublesome.
In addition to the opamplı ton control module for retrieving disabled resistance and supply voltage zener regulated 2X18V AC transformer for 1 k 1W resistor and AC transformer 2X24V RES resistance de 150ohm 2W, 1 k 5 1W and 2W resistor can be used 300 ohm to the RES. The regulator has behind the RES resistance 7812
tda7294-anfi-devresi-tda7294-baski-devre
audio-amplifier-tda7294
tda7294-power-amplifier-professional-audio-amplifier-120x120 tda7294-pcb-tda7294-pcb-layout-120x120 tda7294-schematic-tda7294-anfi-120x120 tda7294-anfi-120x120
TDA7294 Stereo Amplifier circuit PCB drawings:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22820.zip
Published: 2014/03/10 Tags: , ,
6 Comments “TDA7294 Stereo Amplifier Circuit Of Controlled Loudspeaker-Protected Tone
    The Use Of Solder Ball BGA Soldering Repair PlayStation PS3 Slim
    Bga removal and soldering of smd integrated cold soldering automatic soldering BGA chip failures again, BGA, flux, gave detailed information about the use of the hot air gun to solder balls was very common back then, and it was expensive and we were again though his legs now the BGA solder paste with a BGA chip ready bulunoyor zero.
    0.5, 0.8, etc. of various sizes on the market, lead-free solder BGA ball features at an affordable price, lead.
    In the video game consoles the PS3 Slim and Ultra Slim BGA solder ball using the integrated circuit with automatic soldering repair of hot air gun was made for the PlayStation.
    TDA7294 Verstärker Schaltung Der Gesteuerten Lautsprecher Geschützt
    Hallo Jungs, ich habe die neue Projekt wieder mit bewährter Leistung, sound, Preis ein TDA7294 Verstärker IC. Dieses Projekt, zusätzlich zu überprüfen, bevor ich die Aktie Tonnen “verzögert und Led-Anregung Lautsprecher DC Schutzschaltung TDA7294 Stereo” und “2X100-Projekte”, können wir sagen, dass eine Kombination von Verstärker Schaltung (wenn die kleine detail-Unterschiede.)
    Dioden-Brückengleichrichter-Schaltung ist erforderlich für die Futtermittel, filter kondensatoren, die Lautsprecher-Schutzschaltung und-volume, bass, treble Klangregelung Schaltung, wenn das psychische hat zusätzliche Einstellungen für die Karte, verbinden Sie den Ausgang des Netzteil Übertrager Schaltung ausgelegt ist und die Versicherung, die filter Board.
  3. Neeraj TamakheNeeraj Tamakhe
    Hello sir,
    I assembled this and having issue.
    After assembly, I tried to start the amp with 20-0-20 transformer with 40W series bulb connected, the bulb is fully glowing. It indicates that there is obvious shorting somewhere. But I failed to see any shorting.
    I tried isolation amp to preamp by removing one end of 1K 1W resistors which feed power to Preamp. The series bulb still glows, which means the problem is with power amp section. Also tried giving power to protection board and disconnecting the same.
    Would like to mention that, I am using 24v Relay instead of 12v and 7824 instead of 7812. hope it will not affect anything.
    Heatsink is for testing only. I didnt have 47K or 50K Pot hence used 100K pot with 100K resistors.
    1) Where should I look for shorting issue?
    2) What type of thermal switch is used here, normally closed OR Normally Open?
    3) Since I have some 24V Relays from old set and dont want to buy new one, What changes must be done to operate the protection section with 24V?
    https://ibb.co/27mDthP3
    https://ibb.co/wNQn6T0h
    https://ibb.co/FbPMtrXh
    https://ibb.co/TDyjgqgR
    https://ibb.co/GQhdjsmS
    https://ibb.co/Y75HQQPH
    https://ibb.co/GfVfSkS7
    https://ibb.co/k20vNNWB
    https://ibb.co/vgJFLL5
    https://ibb.co/SD44Pmz5
    https://ibb.co/spcPLwLZ
    https://ibb.co/gbxGbm7q
    https://ibb.co/Ngz8btxs
    https://ibb.co/YFwbc9TC
