Car amplifier mono 100w power amplifier tda7293 floor (the 100w 120v dmos) IC dcdc converter section tl494 (pwm control) used. Adding audio input filter can be used as a bass amp. Used in the primary winding of the transformer Transformer ETD29 DCDC 1.2 mm wire 2 × 6, 2 × 0.8 mm wire of the secondary winding of round 21 tour hug.
Source: hifi-forum.de alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16077.zip
Published: 2011/09/02 Tags: audio amplifier circuits, dc dc converter circuit, ic amplifier, tl494 circuit
13.8V 30 Amp Power Supply Circuit LM338K
An amateur radio the radio for the design and applied 13.8V 30A power supply .. on the Internet a lot of similar application schema but this circuit detailed and more powerful writers trodial transformers have used the transformer input EMI filter and soft start circuit’s. In addition to the fan control circuit input, output fuse has LED indicators are provided with control LM338K regulator IC that can give 5 amp power MJ15004 power transistors 30 amp power has been increased by adding power
