3W Amplifier Circuit Battery Powered Stereo TDA7056AB
| Updated on July 31, 2024
TDA7056 3W mono channel output allows a single integrated circuit used in two pieces. 3 … 18V DC supply voltj application has been run by 3 AA batteries.
TDA7056 3Watt BTL audio amplifier
tda7056
The TDA7056 is a mono output amplifier, designed for battery-fed portable radios and mains-fed equipment such as television. For space reasons there is a trend to decrease the number of external components. For portable applications there is also a trend to decrease the number of battery cells, but still a reasonable output power is required.
The TDA7056 fulfills both of these requirements. It needs no peripheral components, because it makes use of the Bridge-Tied-Load (BTL) principle. Consequently it has, at the same supply voltage, a higher output power compared to a conventional Single Ended output stage.
TDA7056 amplifier circuit
TDA7056-pcb-pil-soketi-baski-devre-anfi
Source: http://www.kolumbus.fi amplifier circuit TDA7056 pcb schematic files:
Publication date: 2010/10/28 Tags: ,
3 Comments “3W Amplifier Circuit Battery Powered Stereo TDA7056AB
