32w (50w music power) mono amplifier circuit uses tda2050 amplifier integrated circuit, working voltage is quite flexible (between 10 volts … 50 volts) and can be fed from a single source.
Current drawn by the circuit (max): 5 amps Current drawn in idle: 30ma … 55 mA input resistance 22k frequency range 20khz … 25kHz There are pcb, schema, layout drawings and material list of TDA2050 amplifier circuit
Supply voltage 10…50 Vdc
maximum current 5 A
Idle current 30…55 mA
Output power, Thd 0.5% and Vcc = 36 V, = 4 Ohm 28 W
Output power, Thd 0.5% and Vcc = 36 V, = 8 Ohm 18 W
Output power, Thd 0.5% and Vcc = 44 V, = 8 Ohm 25 W
Output power, Thd 10% and Vcc = 36 V, = 4 Ohm 35 W
Output power, Thd 10% and Vcc = 36 V, = 8 Ohm 22 W
Output power, Thd 10% and Vcc = 44 V, = 4 Ohm 32 W
Harmonic distortions Vcc = 36v, Rout = 4 Ohm, F =1 kHz, Pout = 0.1 – 24 W 0.03 %
Harmony distortions Vcc = 44v, Rout = 8 Ohm, F =1 kHz, Pout = 0.1 – 20 W 0.02 %
Amplification factor 30 dB
Input resistance 22 k
Frequency range 20…25k Hz
Parts | Name | Pcs |
C1, C5 | 0.47 uF |
2
C2 | 22 uF, 50v |
1
C3 | 100 uF, 50 v |
1
C4 | 1000 uF, 50 v |
1
C6 | 2200 uF, 50v |
1
C7 | 0,1 uF, 100 v |
1
IC1 | TDA2050 |
1
R1, R2, R4, R5 | 22 k |
1
R3 | 680 Ohm |
1
R6 | 2,2 Ohm |
1
Published: 2011/06/07 Tags: audio amplifier circuits, ic amplifier, simple circuit projects
LED VU Meter Circuit LM3916 17LED
VU meter circuit 2 Dot / Bar Display driver lm3916 used the audio Gisira upgrades in 1 for TL072 op amp has my voice according to the severity of 17 LEDs flashing audio inputs in addition to the 100k potentiometer connecting the LEDs burning level, you can set. 12v dc circuit is working with VU meters.
