A circuit I tried a long time ago was the only channel I made. The bridge 2030 outputs were powered by transistors. In this application, plus two circuits connected in parallel with the bridge, the power was doubled.
Amplifier supply voltage is symmetric +- 22 volts, unless an error is made, a circuit that is certain to work, also if you type “tda2030 bridge” in the search box on google and search for pictures, you can find many similar applications if you make two from the same circuit on a single plate, you will have a two-channel stereo 400watt amplifier. and use insulators when mounting the transistors to the heatsink.
Sinus 4Ω speakers continuous power: 150 Watts
In 4Ω speakers Peak Power: 200 Watts
Bandwidth (- 3 dB): 10 Hz to 50 kHz
THD 20 W / 1 kHz: 0.22%
THD 100 W / 1 kHz: 0.23% to
THD 130 W / 1 kHz: 0.36%
150 W att Efficiency: 60%
Input sensitivity: 500 mVeff
Input Impedance: 22 K
The peak-to-peak voltage Vpp, with a load resistance at the 4 Ω pending an output of 200 watts, is 80 volts. If we add another additional voltage drop across the output stage transistors added, the supply voltage must a corresponding 200 watts power amplifier least 85 V be – and under full load. The peak current in the peak of the sine wave is about 10 A, i.e. Stereo operation with 2 amps flowing after all 20 A.
If one is satisfied with an effective Continuous output of 2 x 150 W = 300 W, so has the power of the to be controlled Transformer under consideration a middle-amplifier efficiency 60% accounts for at least 500 VA are. Toroidal transformers offer this especially, since they are very one have low internal resistance, and Therefore, in many cases an additional electronic voltage stabilizer can be dispensed with. Substituting other
400W Amplifiers and Power supply circuit diagrams
400w hi-fi stereo Power Amplifier circuit files:
Published: 2009/03/23 Tags: audio amplifier circuits, ic amplifier
MC34063 SMD Step Down DC DC Converter Circuit 3V 12V Adjustable
DC DC converter circuit MC-34063 based on the extra power upgrade yet integrated 500 milliamps of power can give, but the output voltage according to this value changes the operating frequency C6 capacitor and the 70 kHz determined r4 5k potentiometer with output voltage can adjust the materials used SMD small type if you want regular supplies you can do with your circuit
