TDA2005 amplifier circuit 22W 12V
| Updated on September 8, 2024
The output power of the amplifier circuit made with TDA2005 is 22w, the operating voltage is dc 6v-18v, since it is a single source supply, it can be operated with batteries in cars, it is already used in many car stereos.
Current drawn by the circuit (max) – 3 Ampere
Current drawn in idle – 75 mA
Frequency band – 40 … 20000 Hz
Total Harmonic Distortion – 1%
Sensitivity – 300 mV
Amplification factor – 50 dB
tda2005-amfi-tda2005-amplifier-circuit
TDA2005 integrated amplifier circuit pcb, schematics, layout drawings and material list are available. The printed circuit board size is quite small.
comp. vaule pcs.
R1 220 Ohm
1
R2, R3 1,1 Ohm
2
C1 1000 pF
1
C2, C3 10 uF/ 25… 50 v
2
C4, C6… C9 0,1 uF
5
C5 1000 uF/ 25… 35 v
1
IC TDA2005
1
tda2005pcb
tda2005
tda2005fr
Publication date: 2011/06/07 Tags: , ,
1 Comment “TDA2005 amplifier circuit 22W 12V
    Multi Output Regulated Power Supply Circuit
    Positive regulators integrated with the handy multi-output power supply circuit is a low-power multi-circuit can run multi regulator circuit used in the integrated power 12V 9V 5V 3.3V of 1 amp 12 volt (direct) 9Volt (7809) 5Volt (7805) 3.3volt (3LM1117-3.3) Multi Regulated Circuit belonging to the circuit scheme and PCBs prepared by drawing eagle
