TDA1516BQ Amplifier Circuit with PC Card PCB
| Updated on July 7, 2023
Almost all modern sound cards are no longer integrated audio amplifier. For all those who have no external active speakers on the PC operating system, is This small stereo amplifier with a sine wave output power of 2 x 3.5 W conceived. Thus, any passive boxes with impedance between 4 ohm and 16 ohm directly connected to the PC. The compact amplifier is in a bracket mounted and is in the PC Built, the power supply is directly on the PC power supply.
anfi-tda1516bq-anfi-karti-pc-amp-module-anfi-modulu
TDA1516BQ
· Requires very few external components
· Flexibility in use – stereo as well as mono BTL
· High output power (without bootstrap)
· Low offset voltage at output (important for BTL)
· Fixed gain
· Good ripple rejection
· Mute/stand-by switch
· Load dump protection
· A.C. and d.c. short-circuit-safe to ground and VP
· Thermally protected
· Reverse polarity safe
· Capability to handle high energy on outputs (VP = 0 V)
· No switch-on/switch-off plop
· Flexible leads
· Low thermal resistance
· Identical inputs (inverting and non-inverting)
· Compatible with TDA1518Q (except gain)
TDA1516BQ Amplifier with PC Card files
Publication date: 2008/04/17 Tags: ,
1 Comment “TDA1516BQ Amplifier Circuit with PC Card PCB
    5 Amps Current Regulator with MOSFET
    IRF4905 MOSFET with very few elements 5 amp current control, current limiting circuit input voltage line connected on 8 + .40 volts DC current through this circuit is limited to 5 amps 5 amp current draw on the output voltage drops
    Even when loading medium capacitors in the range of some 1000 F µ Einschaltmoment flow in equal currents of 100 A and more. The dining Source Einschaltmoment before these high pulse flows to protect a tripping Fine upstream to prevent backups and high pulse loads of Capacitors to keep away, the DC-1 DEB Inrush current limitation Used.
