TDA1514 alone can provide 50 watts of power supply voltage and a maximum of + – 30 volts mute / stantby temperature protection, overcurrent protection feature. Amp circuit with a few passive components can
TDA1514 Amplifier Circuit
The TDA1514A integrated circuit is a hi-fi power amplifier for use as a building block in radio, tv and other audio applications. The high performance of the IC meets the requirements of digital sources (e.g. Compact Disc equipment). The circuit is totally protected, the two output transistors both having thermal and SOAR protection The circuit also has a mute function that can be arranged for a period after power-on with a delay time fixed by external components.
· High output power
· Low harmonic distortion
· Low intermodulation distortion
· Low offset voltage
· Good ripple rejection
· Mute/stand-by facilities
· Thermal protection
· Protected against electrostatic discharge
· No switch-on or switch-off clicks
· Very low thermal resistance
· Safe Operating Area (SOAR) protection.
Published: 2010/02/16 Tags: audio amplifier circuits, ic amplifier
Modified ATX Power Supply Half Bridge SMPS Project TL494 EI33
ATX SMPS half bridge circuit modified version of the computer power supply circuit output for high voltage power transformer ei33-2 symmetrical re-wrapped. 300 watts of power input voltage 240v AC output voltage + – + 20volt – 45volt set.
High-power amplifier circuit can be used to run additional tone control circuit in 7812 preamf positive negative voltage regulator ICs with 7912 + – 12volt taken out
TL494 SMPS Circuit Modified ATX
