Digital power supply circuit based on voltage-current information stm32f100c4 arm nokia 3310 lcd via an lcd menu system also have detailed gürüntüleniyor the output voltage can be set via the menu, including contrast, current, flash or memory can be on the record. STM32 ARM programming, especially for people dealing with a good example to all source code files in the shared library files in pcb, schema, etc.
Source:radiokot.ru/circuit/power/supply/22/
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18731.zip
Published: 2012/03/23 Tags: arm project, microcontroller projects
STK4172 Amplifier Circuit 2X40W
STK4172-2 power amplifier IC gives you a very low-noise ratio THD stereo 2x40w = 0.4% max supply voltage symmetrical 2x48v dc recommended value 8 ohm speaker with amplifier is feeding on a solid addition to the same pcb with passive tone, voice control circuit.
