Sanyo production STK series power amplifiers integrated belonging to the original circuit diagrams diagram of the manufacturer (SANYO) is the problem will not be a market original NGO integrated hard to find even copy the original design made in accordance with the general power transistors low quality but fake though a lot amp integrated from the transistor from Anfi etc.. gives a much better sound.
STK Amplifier Schematic list
- STK060 27Volt 30Watt
- STK0060 40Volt 60Watt
- STK0060II 41Volt 60Watt
- STK0070 43Volt 70Watt
- STK0070II 45Volt 70Watt
- STK075G 20Volt 15Watt
- STK077G 22Volt 20Watt
- STK078 105 25Volt 24Watt
- STK078 25Volt 24Watt
- STK078G 25Volt 24Watt
- STK080 27Volt 30Watt
- STK0080 46Volt 80Watt
- STK080G 27Volt 30Watt
- STK0080II 47Volt 80Watt
- STK082 105 30Volt 35Watt
- STK082 30Volt 35Watt
- STK082G 30Volt 35Watt
- STK083 32Volt 40Watt
- STK084 35Volt 50Watt
- STK084G 35Volt 50Watt
- STK086 42Volt 70Watt
- STK086G 42Volt 70Watt
- STK0100 50Volt 100Watt
- STK0100II 52Volt 100Watt
- STK0105 50Volt 100Watt
- STK433 23Volt 2x5Watt
- STK435 27Volt 2x7Watt
- STK436 32Volt 2x10Watt
- STK058 25Volt 24Watt
- STK0040 33Volt 40Watt
- STK0040II 36Volt 40Watt
- STK0049 35Volt 45Watt
- STK0050 36Volt 50Watt
- STK0050II 39Volt 50Watt
- STK055 20Volt 15Watt
- STK057 22Volt 20Watt
- STK0025 24Volt 23Watt
- STK0028 25Volt 25Watt
- STK0030 28Volt 30Watt
- STK0039 31Volt 35Watt
- STK4102II 13Volt 2x6Watt
- STK4112II 17Volt 2x10Watt
- STK4122II 20Volt 2x25Watt
- STK4131II 23Volt 2x20Watt
- STK4142II 26Volt 2x25Watt
- STK4151II 27Volt 2x30Watt
- STK4162II 30Volt 2x35Watt
- STK4171II 32Volt 2x40Watt
- STK4182II 33Volt 2x45Watt
- STK4191II 35Volt 2x50Watt
- STK4192II 35Volt 2x50Watt
- STK4231 32Volt 2x100Watt
- STK4231II 23Volt 2x20Watt
- STK4301 31Volt 2x22Watt
- STK4311 35Volt 2x28Watt
- STK4332 23Volt 2x5Watt
- STK4352 27Volt 2x7Watt
- STK4362 33Volt 2x10Watt
- STK4372 35Volt 2x12Watt
- STK4048II 59Volt 150Watt
- STK437 33Volt 2x10Watt
- STK439 39Volt 2x15Watt
- STK441 44Volt 2x20Watt
- STK443 49Volt 2x25Watt
- STK457 18Volt 2x10Watt
- STK459 21Volt 2x15Watt
- STK460 23Volt 2x20Watt
- STK461 23Volt 2x20Watt
- STK463 26Volt 2x25Watt
- STK465 28Volt 2x30Watt
- STK1030 28Volt 30Watt
- STK1035 28Volt 30Watt
- STK1039 30Volt 35Watt
- STK1040 33Volt 40Watt
- STK1045 33Volt 40Watt
- STK1050 36Volt 50Watt
- STK1059 38Volt 55Watt
- STK1060 40Volt 60Watt
- STK1070 43Volt 70Watt
- STK3042 36Volt 2x40Watt
- STK4036 35Volt 50Watt
- STK4036X 36Volt 50Watt
- STK4038II 38Volt 60Watt
- STK4038X 39Volt 60Watt
- STK4040II 42Volt 70Watt
- STK4040X 42Volt 70Watt
- STK4042II 45Volt 80Watt
- STK4044II 51Volt 100Watt
- STK4046XI 55Volt 120Watt
- STK4048 55Volt 150Watt
- STK0059 38Volt 55Watt
Sanyo STK Amplifier Schematics
Published: 2011/06/08 Tags: audio amplifier circuits, ic amplifier
Electronic Compass Circuit KMZ52 Magnetic Field Sensor
Electronic compass circuit used in the main kmz52 magnetic field sensor integrated in the market, is there I do not know, but a different application also circuit more complex does not count eagle prepared with schematic drawings, PCB drawing, measuring and testing on fluoroscopic images there.
