Speaker Short Circuit Protection Circuits
| Updated on April 2, 2020
Amplifier features delay, dc protection and temperature monitoring across the speaker protection circuits. Since the application of short circuit protection is not flexible, most speakers are not in the protection circuit. You can use the appropriate one according to your amp, which will include various short circuit protection circuits.
For the first circuit transistor amp circuits, it detects current through the equalization resistors of the power transistors and triggers the DC protection circuit. You can add to your current protection circuit or you can add another transistor and control the relay directly.
Note: I do not recommend doing the experiments by short-circuiting the direct amp output, adjust according to the current drawn on the load, then measure the current drawn by your amp and establish a connection accordingly or max. run at load and set the protection circuit to work, then increase the trimpot value a little and try again at max power. This time, the protection circuit will not work, so the current drawn will be active when the short circuit is high. When performing tests, take into account sudden peaks, especially in bass
Speaker short circuit protection circuit diagram and pcb drawing
The E + section will be connected to the equalization resistor of the transistor (2sc5200 or IRFP240) from the positive supply stage.
speaker-short-circuit-protection-circuit-diagram-and-pcb-drawing
The circuit diagram is not very clear for the connection below, see the sample diagram about the amp, dc protection connection.
short-circuit-protection-schematic-diagram
The second speaker short circuit protection circuit can be used in many more flexible amp circuits, but the resistance of the resistor must be connected to the loudspeaker line with a resistance of 0.2 or 0.5 ohm, and the power of the resistor will vary according to the amp.
speaker-protec-circuit
short-circuit-protection-relay-resistor
Simple version (untested)
simple-protection-untesded
Publication date: 2020/04/02 Tags:
2 Comments “Speaker Short Circuit Protection Circuits
    Circuits de protection contre les courts-circuits des haut-parleurs
    L’amplificateur offre un retard, une protection cc et une surveillance de la température à travers les circuits de protection des haut-parleurs. Étant donné que l’application de la protection contre les courts-circuits n’est pas flexible, la plupart des haut-parleurs ne sont pas dans le circuit de protection. Vous pouvez utiliser celui approprié en fonction de votre ampli, qui comprendra divers circuits de protection contre les courts-circuits.
    Pour les premiers circuits ampères à transistors, il détecte le courant à travers les résistances d’égalisation des transistors de puissance et déclenche le circuit de protection DC. Vous pouvez ajouter à votre circuit de protection actuel ou vous pouvez ajouter un autre transistor et contrôler directement le relais.
    Remarque: je ne recommande pas de faire les expériences en court-circuitant la sortie directe de l’ampli, ajustez en fonction du courant consommé par la charge, puis mesurez le courant consommé par votre ampli et établissez une connexion en conséquence ou max. fonctionner à charge et régler le circuit de protection pour fonctionner, puis augmenter un peu la valeur du potentiomètre et réessayer à la puissance maximale. Cette fois, le circuit de protection ne fonctionnera pas, donc le courant consommé sera actif lorsque le court-circuit est élevé. Lors des tests, tenez compte des pics soudains, en particulier dans les basses
