A lot of professional preamplifier circuit that hosts the volume control bass, treble, medium, balance, mute, loudness (low bass tones reinforcing) and volume control settings can be made. Professional Preamplifier NE5532 op amp circuits used in the two units working voltage + -15 symmetrical drawing pcb’s regular and all materials on the market. Pa7000 preamplifier circuit clone version of `fame ..
Source: forosdeelectronica.com/f30/preamplificador-gemini-pa700-esquema-pcb-29623/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19337.zip
Published: 2012/07/22 Tags: audio control circuits
Mechanical Clock Circuit ATmega8
In fact, what lies At the forefront of the digital but mechanics should have been a wonderful project:) is an interesting time in the atmega8 microcontroller time and when the mind comes to the display, lcd, led, but the author is using a different method to display the time information. Figures are the red and black color Acrylic glass (Plexiglas) prepared with the hour and minute change pushed figures created with servo motors parts. Hardware has been used a lot in the account book to one side.
Microcontroller, pcb, schema of the project source codes and Plexiglas (acrylic glass) parts of the measures given the DFX format.
Professionelle Stereo-Vorverstärkerschaltung
Viele professionelle Vorverstärker-Schaltung, die die Lautstärkeregler Bass, Höhen, Medium, Balance, Stummschaltung, Lautheit (niedrige Basstöne Verstärkung) und Lautstärkeregler Einstellungen beherbergt, kann gemacht werden. Professionelle Vorverstärker NE5532 Operationsverstärker Schaltungen in den beiden Einheiten Arbeitsspannung + -15 symmetrische Zeichnung PCB Regular und alle Materialien auf dem Markt verwendet. Pa7000 Preamplifier Schaltung Klon Version von `Ruhm ..
