Feature a very high level transmitter and receiver circuit consists of two parts of a project are provided with the main control PIC18F452 PIC16F84 sensors are connected to the transmitter circuit based on the information received from sensors on the lcd screen is displayed as text and graphical
MPX4115 pressure sensor TC77 SPI temperature sensor H1 humidity sensor wireless RF communication RX + TX433 modules used also DS1307 RCT and 24C256 i2c EPROM entegreleri in the project used the software CCS C (PCWH CCS compiler) prepared with source c code eagle pcb schema files located in the heat, humidity , pressure calibration settings explained.
This project uygulamasa your hardware, software, a very good example for the use of the sensor can be integrated
Pressure reading, relative humidity, temperature and away off the outer display.both Celsius or Fahrenheit & mbar / hPa or mm Hg supported weather station. With calendar and clock. Easy three button user menu. 42-hour history display (curve). Automatic memory and to show all the high and low values. PIC 18F452 4 MHz, works in sleep mode to save power. Sensors is only open when needed ..
PIC18F452 RF Humidity Temperature Project
Now this was a great project! I’ve tried various LCDs currently testing all the sensors had to be a complete, wireless communication has to be perfect. Still, here’s the result: I hope you enjoy it! Circuit 9V battery can power a small, but more want to get a good pair of AA-size batteries. 6-pack will last a few months. Consumption for base station and about 8 9 mA in sleep mode when enabled only 2 to 3 m (LCD remains are.) Transmitter is slightly less.
Receiver (base station) is active for 5 seconds and then goes to sleep for 45 seconds. The transmitter takes a nap every 30 seconds or so. In the Menu mode “buttons” menu pushing (what a name is entered?) For 1 second. Scan and changes the value of “min” and “plus” buttons are made. When in normal mode (for example, in the picture above) and “minute” and “plus” buttons with different backgrounds can browse. All of these controls if the processor is in sleep mode wakes up will be.
In the left hand side we have the LCD (top-down 🙂 Return Temperature, Relative Humidity, Calendar and Clock in the outside temperature, pressure,. Correct: Last 42 hours of high-value, bar chart, histogram (right most recent value), is a low value.
All sensors are read and the LCD (left side) is updated every 50 seconds. The histogram on the clock (for example, 10h00, 17h00, 22h00, …). All data is stored in EEPROM and power up when installed will be updated. In case of a power outage (or), no data (nor will be the date) battery replacement lost.
PIC18F452 CCS C RF Humidity Temperature Circuit schematic pcb ccs c source code files
Åžifre-Pass: 320volt.com
Published: 2009/04/09 Tags: microchip projects, microcontroller projects
5V 2A Switching Regulator Circuit Mosfet 2SJ552 LM311 Control
Switched control of the control circuit lm311 provided with wi-zero3 in testing a device like a PDA or used (I’m not sure) Circuit input voltage is 5 pcs panasonic AA batteries connected in series provided
5V 2A Switching Regulator Project
