PIC16F628 Stepper motor control LMD18245
| July 10, 2023 Updated
Stepper motor control, pic16f628 microcontroller is used in the driver circuit, there is LMD18245 3 Ampere, 55 Volt DMOS full bridge motor driver integrated in the motor control. There are all the resources (pcb, code, schematic, etc.) of the working frequency 20mhz step control project prepared with the PIC software assembly. The author used the circuit with Mach3 and SheetCAM programs.
LMD18245-PIC16F628 Stepper Motor Controller
This is a new project geared to provide the community with a low-cost PIC based microstepping controller It will provide Full step, 1/2 step 1/4 step, and 1/8 stepping modes, plus will be able to drive 3A – 55V per coil
lmd18245-step-motor
36VDC-toroidal-ransformer-Mach3-SheetCAM-lpt-cnc-step-motor
pc-step-motor-driver-Opto-Output-Interface-Schematic-circuit
Source: fromorbit.com PIC16F628 Stepper motor control LMD18245 pcb pic assembly source code alternative link:
Published: 2008/07/31 Tags: , , ,
1 Comment “PIC16F628 Stepper motor control LMD18245
    Alphanumeric Display Drivers Circuit with PIC16F874 Hi tech C
    Pic16f874p alphanumeric LED display driver circuit board with microcontroller builds on the applied bred led display 74HC238, 74HC238 is driven by com also has a connection with max233 pcb printed circuit drawing in addition to the (eagle) there. PIC Software HiTech PICC compiler written in VHDL source code are in addition PALCE16V8. Sisis supply LM2940 regulator in there. Circuit with 9v battery can run.
    PICmicro Alphanumeric Display Driver
