Handmade pretty stylish LED display digital speedometer tacho meters. Source or assembly code pic16f874 PIC16F877 can be done with the circuit and wiring diagrams directly from the preparation given the 33-hole leds pcb layout on a plaque made
analog instrument into a digital tachometer with analog bargraph LEDs. The meter can measure and display a speed range from 0 rpm to 8000 rpm and higher in 250’er increments. Intermediate values are indicated by a pulse-pause ratio of the next higher LED. This is admittedly a bit of getting used to when it flashes in the view, but can be improved in the software.
LED tachometer Circuit
The LED tachometer is based on the PIC 16F874/877 which can control the LEDs directly with its wealth of I / O pins and makes the overall circuit is therefore very simple.
Was programmed the circuit for a 4-cylinder gasoline engine. The speed is measured directly or via divider resistors at Zündspulenunterbrecher. Configured the PIC on a clock frequency of 20MHz. There were all port pins except PORTA, 0 used as LED pins. The circuit is connected to a total of 4 cables. (+ Ub, GND, CLOCK, backlight).
Publication date: 2009/09/10 Tags: led projects, microchip projects, microcontroller projects
PIC18F4550 Development Board and PIC18F4550 Examples
PIC18F4550 for a simple handy trial development board and various application circuits are also circuits Eagle prepared by the PCB diagram drawings and PIC C language prepared by the software (MPLAB,. C. Hex,. Mcw,. McP etc.) Files provided in abundance There are examples
Application list
PIC18F4550 USB experiment board
The SPU’s associated servo control circuit (6 servo output PIC18F252)
USB shutter control circuit (PIC18F252 PIC18F4550)
4N25 opto-coupler interface card isolated MOSFET relay control
Stepper motor control card (pic output MOSFET drivers for the IRF630)
USB Connected “Rotary Encoder” (PIC18F250 focus control)
USB Connected “Windows Media Player” control (forward, backward, volume, play, stop)
