Two-Channel Dimmer Circuit with PIC16F84A LED Level indicator
| July 12, 2023 Updated
PIC16F84 Automatic Dimmer. It is specially designed to drive high power lamps used in stage lighting up to 2400W. Preset brightness levels, dimming rates, flash on and off buttons, etc. It has all kinds of control features. It can be dimmed up or down manually or automatically and has LED bar graphs to indicate brightness levels, dimming rates and more.
Dimmer Circuit Main Features
  • High power lamp control
  • Maximum lamp brightness preset
  • Preset minimum lamp brightness for filament preheating
  • Auto or manual dimming between brightness presets
  • Separate flash on and flash
  • Flash brightness preset
  • Programmable dimming speed up to 40 seconds on the fly
  • A and B dimming ratio selection
  • Lamp brightness indicator
  • Automatic dimming and dimming indicator
PIC16F84A Dimmer Circuit
dimmer-circuit
Source: http://www.siliconchip.com.au/cms/A_30600/article.html
Dimmer Circuit PCB schematic PIC16F84A pic assembly source code alternative link:
Published: 2008/09/04 Tags: , , ,
1 Comment “Two-Channel Dimmer Circuit with PIC16F84A LED Level indicator
    PIC16F88 RF Remote 433MHz Transceiver Switches
    RF communication system operating with a switching circuit controlled by the water pump 1000 watts of project files are all sources.
    if you want to switch devices rated over 1000W or control water pumps, then you need the UHF Remote Mains Switch described here. It can switch devices rated at up to 2500W over a range of up to 200m. That’s 10 times the range typically available from the low-cost commercial units
    Controls the UHF Remote Mains Switch Up to 10 UHF Remote Mains Switch units can be controlled 16 encoder selections 200m range On/off switching Handheld operation 9V battery supply Transmit indicator Transmit error indication
