Automatic Rabbit Feeding System ATmega8 Timer
| September 9, 2024 Updated
In fact, feeding, feeding various timing circuits used for business. Generally puzzling, time-consuming mechanical parts is getting no special circuitry to rabbits in this project but the authors have used to feed rabbits 🙂 crafted with a software pascal Pascal example might be for users.
Circuit based on Atmel ATmega 8 2 × 16 LCD also displays information on the source code of the circuit prepared with eagle pcb, diagram drawing there.
Atmega8-microcontroller-based-feeder-pascal-avrco
atmega8-ld-buttun-timer-circuit-pcb-pvc
The program basically consists of a real-time clock and a PPM signal generator to drive a servo motor. The servo motor, which rotates an eccentric shaft (small hooks), places it in precise angular positions. Each angular position releases a dose of tilt
Four buttons are used to set the clock (plus and minus hours, plus and minus minutes). A button allows you to manually advance the angular positions cycle to set the mechanics and reset everything at startup. The 2×16 LCD display shows the day, time, mode (manual, automatic). The on-site programming connector makes it very easy to change the software.
The trigger times (06:00 and 18:00) can be changed in the program, but not in “live”; I have no problem with that. The merit of this success lies in the program: it is written directly in PASCAL.
Author: Silicium628
Source: silicium628.fr alternative link:
Published: 2011/05/29 Tags: , ,
1 Comment “Automatic Rabbit Feeding System ATmega8 Timer
    Li-Ion Lipo Battery Charging Circuit pic16f876 Microcontroller
    With the charging circuit lion lipo life, lead batteries can be charged also NiCad and NiMH batteries delta slower without charge as may be specified (google translate) charging circuit pic16f876 is controlled by a charger, battery voltage and current information 2 × 16 LCD is displaying over.
    Power transistors, MOSFETS (irfz44) is used for high power (0-5A) Supply voltage: 6 to 20V Current: 20mA – 5A Output: 20mV – 20V 0
    Software source C prepared with micro c, hex codes and other schemes (+ OrCAD) files are
