Obstacle Sensing Robot based on the SV-328 control module circuit Orangutan Orangutan SV-328 is a module that you have internal engine driver Atmel microcontroller, ATmega328P (Toshiba TB6612FNG) can be connected to two DC motor output power 1 .2A max. Peak 3 amps.
Obstacle detection in two SHARP GP2Y0A41SK0F sensor is being used. Obstacle Sensing Robot software crafted with source Atmel IDE Studio 6 C, HEX, etc. have the codes.
source: mikrokontroler.pl alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22959.zip
Published: 2014/05/06 Tags: avr project, microcontroller projects
STM32F4 Discovery DM-LCD35RT LCD Touch Snake Game
STM32F4 Discovery kit is built on the snake game is quite detailed work display 3.5 TFT LCD module DM-LCD35RT inc is done via already built on the implementation of the project modules, lcd connection information and library codes for different projects may be useful. In addition to “BMP encoder” in terms of information and code files
SV328 Modular Robot Hinderniserkennung Projekt
Hindernis-Sensing-Roboter auf der Grundlage der SV-328-control-Modul-Schaltung Orang-Utan Orang-Utan-SV-328 ist ein Modul, das Sie haben interne Motor-Treiber Atmel mikrocontroller ATmega328P (Toshiba TB6612FNG) verbunden werden kann, um zwei DC-Ausgang motor power 1 .2A max. Haupt 3 Amp.
