PT100 Temperature Sensor Circuit
| Updated on August 3, 2019
PT100 temperature sensor is used, the use of a simple circuit for OPA129U op amp PT100 sensor detects temperature OPA129U 0-10 volt output is between. Commissioning of the pcb (active elements of smd), schema, and there is Additional placement drawings like PT100 temperature, resistance to the change table and calculation formula.
pt100-termokupl-pt100-temperature-pt100-circuit
Source: zzzorg.pagesperso-orange.fr/conver.htm alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19242.zip
Publication date: 2012/07/13 Tags:
2 Comments “PT100 Temperature Sensor Circuit
    HiFi Power Amplifier
    The recent aquisition of a pair of vintage Infinity RS-5b speakers prompted a search for an amplifier to drive them. According to the documentation that came with my speakers, an amplifier between 35W and 135W is recommended (not my 10W at 10% THD piece of garbage Sharp 3-in-1). Initially, I looked at commercial amplifiers (Yamaha, NAD, and Rotel), but was disappointed at their fairly pedestrian distortion figures. Thus a new hobby project was born 🙂
    PT100 Temperatursensorkreis
    PT100 Temperatursensor wird verwendet, die Verwendung einer einfachen Schaltung für OPA129U OP-Verstärker PT100 Sensor erkennt Temperatur OPA129U 0-10 Volt-Ausgang ist zwischen. Inbetriebnahme der Platine (aktive Elemente von SMD), Schema, und es gibt zusätzliche Platzierungszeichnungen wie PT100 Temperatur, Widerstand gegen die Änderungstabelle und Berechnungsformel.
